05-03-2010, 10:12 PM | #1 |
tire and wheel question again...from the new guy
Hey guys this is my first post. I have read a lot of the threads about drops of different heights and wheel and tire combos. I am restoring my 77 sierra grande. My Dad bought it new in 77. It was my high school truck. I hope for my son to drive it when he is 16. (He's almost 1 now!)...
Any way I think I am going to go with a 2.5-4 drop to start. I would like it a little lower, but my Dad doesn't want too low. I am looking to just be at or just above the height of the tire. I may cut the front coils and remove a leaf if it is too high. I am going with 20x10 in the rear and 20x8.5 in the front. What back space and tire size would you recommend? I am wanting to stay the same diameter that I have now. (235/75/15) About 27.5-28 inches tall. I will post some build pics soon. Here is what I have planned: 1. 2-tone orange metallic with pearl white. I am going to paint the top of the cab pearl white also. Same old look with updated paint colors. 2. 4 wheel disc brakes 3. Full trim package. 4. New stock interior. More details later. Thanks! |
05-04-2010, 09:21 AM | #2 |
Re: tire and wheel question again...from the new guy
Sorry about the long post. Any tire size suggestions?
05-04-2010, 10:38 AM | #3 |
As far as your drop goes I would do at least a 3-5 drop. I am currently saving for my drop and just from looking at pictures it looks like 3-5 sits about an inch above tires, 4/6 sits level with the top of tires, and 5-7 tucks about an inch.
As far as backspacing goes I can't help you there yet but I am sure others will chime in. Sounds like a fun project by the way. My Dad and I are working on my 83' dime together. |
05-04-2010, 11:06 AM | #4 |
here is a tire size calculator, you can start looking at diff sizes
http://www.1010tires.com/TireSizeCal...?action=submit your offset on the rear needs to be between 3-5 so the wheel sets just inside the fender, the front needs to be between 4-5
Fuzzy Dice Club Member 87 Crew SWB Build for the crew http://67-72chevytrucks.com/vboard/s...d.php?t=430082 http://www.cardomain.com/ride/3232925 90 burb 2wd Build Thread For The Burb! http://67-72chevytrucks.com/vboard/s...d.php?t=383055 Last edited by justpball; 05-04-2010 at 11:10 AM. |
05-04-2010, 11:40 AM | #5 |
Thanks for the info. What's the best way to get a 5 inch drop in the back? I was going to get a 4 inch kit with hangers and shackles. I know that a lot of guys recommend a c-notch with 5 or more inches or drop. Initially I was going to get a 5.5 inch rear flip kit from classic performace with a with a c-notch for the rear, and a 12 inch disc brake kit with 2" drop spindles and 2 inch coils for the front. I am also going with tubular control arms.
I think the 4/5.5 will be too low for my Dad's taste and also not enough rake for mine. Would you get 1 inch new coils or just cut my existing ones? On the rear should I get the 4 inch drop and remove a leaf? Do I need to c-notch? I don't really want any bottoming out issues. |
05-04-2010, 06:12 PM | #6 |
Squarebody Aficionado
Do the flip kit from the beginning the shackles and hangers might not be low enough for you.
05-04-2010, 06:23 PM | #7 |
Slots go on anything!
Do the flip kit. Check out my build thread for some pictures. I am running a 215/70/15 on a 6.5" van ralley in the front, and a 255/70/15 on an 8" truck ralley on the rear. The front has a coil cut, with a 2.5" spindle, and the rear is flipped. I am very pleased with the way it sits, and it hadn't hit the frame without the C- Notch. That being said, it is in my shop now with the bed off and the c-notches being installed, just in case. CPP had really great prices on the stuff, so I got it all from Jeff.
1974 Jimmy- 5.3/4L80e/NP241 |
05-04-2010, 07:41 PM | #8 |
Tire sizes I recommend for those wheel sizes & proposed drop (4/6 max drop) would be 255-40-20 @ 28" tall (F) & 295-40-20 @ 29" tall (R).
Backspacing is subjective to the owner. Some guys want the wheels tucked in; others like them 'flush' w/the body. Which do you prefer?
05-04-2010, 10:15 PM | #9 |
Beautiful truck Jonboy. I like your stance a lot. Just have to talk my Dad into it. He is leaning toward a 3/4 drop. 2 inch drop spidles with 1 inch coils in the front. Hangers and shackles in the back. We'll see....
Scoti I have decided on the exact tires you recommended. I think I want the tires slightly inside the fenders. I was thinking 4 3/4 for the front backspacing and 5 1/2 for the rear. Does this sound right? Thanks for the replies. |
05-04-2010, 10:17 PM | #10 |
baclay9, that's cool you are working on yours with your Dad too. I'd love to see a picture.
05-05-2010, 12:43 AM | #11 | |
05-05-2010, 11:09 AM | #12 |
Thanks Scoti,
I know that I have seen it on the forum somewhere, but what drop and backspacing to you have? I think I would like mine just a touch higher. |
05-05-2010, 12:06 PM | #13 | |
18/20" Polished TT's 18x8 w/5.25" bs 245-45-18 Dunlop SP9000's 20x10 w/5.00 bs 295-40-20 Dunlop SP9000's 20" Coys 20x8.5 w/5.25" bs 255-40-20 Toyo Proxes 20x10 w/5.50" bs 295-40-20's Toyo Proxes Old School 15x6.5 OE van ralley 215-70-15 BFG Radial TA 15x8 OE truck ralley 255-70-15 BFG Radial TA
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 05-05-2010 at 12:07 PM. |
