Old 05-03-2010, 10:54 PM   #1
Deryl
Noisy Speedometer
First off, I did a search, but did not see anything that specificaly addressed how to lube the speedometer. I finally put a cable on my 63 and proud of myself I took it for a drive. The speedometer itself is noisey as hell, maybe because I have driven it for five years without a cable. The searches I did mostly referenced the cable, but the noise is obviously the speedo head. I didn't see anything, other than random suggestions, how to lube the head. Can it be done sufficiently in place or does it need to come out. As usual any help is appreciated.
D's 63
Deryl is offline   Reply With Quote
Old 05-04-2010, 12:15 AM   #2
Gus63
Re: Noisy Speedometer
Almost the same exact thing is happeneing to me right now on my 63. I ended up disconnecting the cable on mine today because I can't deal with it any more. I couldn't get in there to lubricate it, so I would guess it would be best to take it out
Gus63 is offline   Reply With Quote
Old 05-04-2010, 06:21 AM   #3
63sbssbbw
UCA63
63sbssbbw's Avatar
Mine was making quite a racket too
I did manage to get the straw into the speedo head without making a big mess.
I think it helped that the can was on the full side.
even calmed the needle down a bit too.
T
member#7816
"63 sb ss bbw 350\350 12 bolt rear Pwr Fr Disc PS tilt
'61 GMC in progress
'63 GMC to use for parts
'90 Chevy Ext cab sbfs 5.7l (current d d)
63sbssbbw is offline   Reply With Quote
Old 05-04-2010, 04:56 PM   #4
NF65Fleetside
NF65Fleetside's Avatar
I have the same problem, it kinda does it when it wants though...needle bounces a tad but sometimes the thing just goes crazy and brings the noise with it too. so you guys say I can just lube it some how and things will mellow out?.....sorry, not trying to jack the thread but just find out a fix as well.
NF65Fleetside is offline   Reply With Quote
Old 05-04-2010, 05:22 PM   #5
Bears63
...just another truck junkie..
Bears63's Avatar
Grease the gears on those speedos! Yes, you have to remove the panel and pull the speedo out of the panel to do it properly, but if you don't put grease on those gears they will break or strip out eventually. It's a pain but it doesn't have to be done very often either.
Mike "Bear" Shea
Bears63 is offline   Reply With Quote
Old 05-04-2010, 11:04 PM   #6
LILRED66
LILRED66's Avatar
90% of the time, the noise is coming from the cable, since it is not rotating freely. Pull the cable from the back of the speedo...can be done by contorting you body and hand, to reach the nut on the cable at the back of the speedo, usually finger-tight. With the cable loose and the end snaked out from under the dash, squit 3-n-1 oil or other penetrating oil into the cup and into the cable cavity. Slowly, with the help of gravity, the penetrating oil/lubricant will make its way down the cable and lubricate the inner square drive.
For a more thorough remedy, remove the cable entirely, soak in parts washer and repeat above sequence, until the cable is sufficiently cleaned. Follow-up with proper lubrication. By freeing up the inner square drive, the cable will operate freely and the noise & jumping needle will disappear.
In order to lubricate the speedo head, the dash cluster must be removed from the dash and the speedo unit removed from the cluster. At that point, apply a liberal amount of dielectric grease or lithium grease to the nylon gears. This will allow the speedo to operate smoothly, quietly and freely.
LILRED66 is offline   Reply With Quote
Old 05-05-2010, 01:49 AM   #7
NF65Fleetside
this forum is awesome! truck guys rock!
Old 05-05-2010, 05:18 AM   #8
63sbssbbw
UCA63
63sbssbbw's Avatar
LOL I guess it helps to be 5'9" a buck fifty, I can get under there pretty good
kind of like yoga for us truck guys
T
member#7816
'61 GMC in progress
Old 05-05-2010, 08:46 AM   #9
Bears63
Bears63's Avatar
Yep, most of the time it is the cable, and that should always be checked first. But, if that's been done and the speedo is still making noise then it's time to yank the panel and lube the gears.
Mike "Bear" Shea
