Old 05-03-2010, 11:13 PM   #1
**grumpy**
**grumpy**'s Avatar
Burb or panel lower quarters...
Where can I find lower quarter skins for a panel or burb??
Or will the shortbed truck skins work?
Road Hounds
**grumpy** is offline   Reply With Quote
Old 05-04-2010, 07:24 AM   #2
Demmit_Hemmit's 65
Demmit_Hemmit's 65's Avatar
Re: Burb or panel lower quarters...
Yes, the lower bed panels will work with some work. Hemmit
Demmit_Hemmit's 65 is offline   Reply With Quote
Old 05-08-2010, 12:21 PM   #3
**grumpy**
**grumpy**'s Avatar
Thanks D
Wheres the cheapest place to buy lower skins?
Road Hounds
Old 05-11-2010, 10:39 PM   #4
Fudge
Fudge's Avatar
I saw some lower quarter panels on Ebay. The guy had three. The ones for in front of the wheel wells and the drivers side rear. Wouldn't you know I need the passengers rear. I think I was searching under "62 chevy truck or 62 chevy panel truck. Hope this helps.
Fudge is offline   Reply With Quote
Old 05-12-2010, 02:15 AM   #5
padresag
I think to complete the regular panels at the bottoms, the addition of the cheaper weld in replacement rockers will give you that underneath bottom piece that goes under to meet up with the inner panels that the suburban or panel body uses. cut and weld to achieve it
ron
padresag is offline   Reply With Quote
Old 05-12-2010, 09:29 AM   #6
Muleman100
Muleman100's Avatar
When rebuilding my 66 Burb I couldn't find any repair panels so I had to buy a donor vehicle to cut up and weld on the donor panels. This is tooooo expensive solution to replace panels but it worked for me.
" I never think of the future. It comes soon enough " - Albert Einstein
Muleman100 is offline   Reply With Quote
