Old 05-04-2010, 02:44 AM   #1
Joemomma1
Joemomma1's Avatar
67-69 chevy 6 cyl power steering worth?
I have the chance but dont know if I should pick it up. Is there any interest for this part?
Joemomma1 is offline   Reply With Quote
Old 05-04-2010, 05:59 AM   #2
bestchevyfan
Re: 67-69 chevy 6 cyl power steering worth?
Hi, if you do i would like first chance to buy it .let me know. Thanks,buddy
bestchevyfan is offline   Reply With Quote
Old 05-04-2010, 11:54 AM   #3
NC67Chev
NC67Chev's Avatar
It depends on the "completeness" of the set-up, but they definitely have value. I've seen them sell from $75 to $250. The more "complete," meaning brackets, ps pump, water pump pulley, alternator pulley (if a double one is required), harmonic balancer, etc.
There are various configurations between cars and trucks. I've pulled two set-up off of Nova's (one a 72 & one a 74). One with A/C and one without. They were different and thus required different things to make them line up correctly.
If the seller knows anything regarding the value/demand, they will insist in selling all pulleys and brackets as a unit. If I were buying, that's the only way I would touch it. Just my 2 cents.
1967 Chevy C-10, 250 L6, Powerglide, 3.73, SWB, Fleetside
Upgrades: Power steering, Offset air cleaner, Rear Sport bumper, 3 point safety belts, HEI, -1/-2 springs, 16x5 wheels, McGaughy's disc brake conversion, Sway bar
NC67Chev is offline   Reply With Quote
Old 05-04-2010, 02:42 PM   #4
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
^NC is absolutely right!^
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 05-04-2010, 07:44 PM   #5
Joemomma1
Joemomma1's Avatar
I went and took a better look but I doubt its stock stuff.
Old 05-04-2010, 08:05 PM   #6
NC67Chev
NC67Chev's Avatar
I'm not sure what that is from, but I'm sure somebody else will. Is that a "63" written on the manifold? Is that maybe a clue, hmmm.....I wouldn't pick that up if it were me, but I'm picky.
Old 05-04-2010, 08:18 PM   #7
Joemomma1
Joemomma1's Avatar
Can this set up be used? From a 77 chevy C10.
Old 05-04-2010, 08:33 PM   #8
NC67Chev
NC67Chev's Avatar
nope. The set-ups that are so sought after are from '75 and older. The heads were changed starting in '76.
Old 05-04-2010, 09:33 PM   #9
Mister laugh
Those pictures don't look like an integrated head to me. I think that is a good setup. I have been wrong before and I'm no expert but i dont think that is integrated head.
Mister laugh is offline   Reply With Quote
Old 05-04-2010, 11:46 PM   #10
Joemomma1
Joemomma1's Avatar
The truck is originally a diesel but has been changed so the 6 can be from anything. Is there a way to check?
Old 05-05-2010, 12:08 AM   #11
Mister laugh
After a little bit of googling that is not an integrated head engine, the powersteering setup should work for you. Some of those pulleys dont look original to me though, so make sure you grab them ALL to make sure it works for you.
Old 05-05-2010, 01:31 AM   #12
Jbesotes
Jbesotes's Avatar
That '77 Chevy pump should work the power steering pumps work all the way up '80. I have a pump on mine that was off of a '75 Chevy. and it works great! It works almost too good with my stock steering wheel. The pullies that are on the fan in the picture will work but they have a serpentine belt setup on them, which doesnt make a difference it just wont be used.
Also if that chrome valve cover says Chevrolet on it and if it is in good shape I would grab it too they run from $90- $160 from what I have seen.
Hope this helpes you get the power steering working.
'70 Chevy Shorty
I support our troops!! Thank You to all that have served!!
Jbesotes is offline   Reply With Quote
Old 05-05-2010, 08:32 AM   #13
NC67Chev
NC67Chev's Avatar
I don't think I was very clear in my reply. The pump isn't what I was focusing on. The pump might work fine, but the pumps are also readily available for not much. The brackets are the issue, which I don't think are correct for a non-integrated head. The brackets are where the value of the set-up comes into play. Maybe somebody rigged it up to work, I don't know. If you can bolt it back up, then maybe you should buy it if it's cheap. However, if you can't bolt it back up, then I wouldn't. Here is a picture showing what the saddle portion of the correct brackets looks like:
