Looking to buy my first 1970 - Need Help
Hi all:
I have been looking for about 2 years and been on here alot learning as much as I can. I final found a truck that I can afford. Some questions: 1- The rear was swapped out for a mid 80's camaro with disc breaks. Assuming the complete rear was swapped that would mean a 7.5" 10bolt.... How would that handle the torque of a mild 350? 2- How do I get the replacement break pads? Just ask for the mid 80's camaro pads? 3- The 3 speed manual transmission was swapped out for a 4 speed. I thought he said a Borg Warner but could be wrong. Would I match the Clutch to the motor or the trans? I am assuming the clutch and pressure plate would need to match both motor shafting and trans shafting. 4- He said the windows are a little difficult to wind back up. Does the arms usually need greased on these or am I looking at repalcing them. I know these are some stupid questions but never looked at a updated truck before... Specs of the truck: 1970 Longbed. 350, 4 speed, power steering and 4 wheel disc brakes. All rusted sheet metal repalced. nice rims and newer tires.
2013 Chevy Silverado, Z71, 5.3L, 4 door 2005 Chevy Silverado, Z71, 5.3L, 4 door, 3.40 Support the Troops. ![]() |
PROJECT 7DEUCE
![]() Join Date: Dec 2002
Re: Looking to buy my first 1970 - Need Help
Sounds like someone swapped in some camaro running gear. The window regulators may need some grease on the gear teeth to get them going smoothly again or they are replaceable for about 50$ from out board vendors iirc. As far as brake pads just as for the camaro units and that rear end should hold up as long as your not doing netural drops or big smokey burn outs with it.. Thats the best I know about what ya asked if im wrong someone will correct me I hope.
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
is there any way I can determine what Trans is in it.
Also any help with the Clutch question.
#4 | |
Shake and Bake!
![]() Join Date: Feb 2010
Take some pictures of the trans and post them, I'm sure we can figure it out. The clutch won't be a big issue, once you know what trans it has just order a clutch kit for that trans/350 setup.
"All tyranny needs to gain a foothold is for people of good conscience to remain silent." Thomas Jefferson "You are remembered for the rules you break." General Douglas MacArthur "Support Our Troops And The NRA" |
OK Im going Saturday am to look at it.
Resident Curmudgeon
![]() Join Date: Dec 1999
Here is some help IDing the transmission.
The Borg-warner T10 or Super T10 4 speed is a stong unit and the one you want. Used thru the 70's in the 2nd gen Camaros behing V8's. The T5 not so much, used behind V6's and 305 V8's in 3rd gen Camaros.
Currently on or near the homestead: 67 Chevy SWB 2WD stepside 350/3 on tree (Pat's) 67 GMC SWB 2WD Fleet 402/auto (Brian's under construction) 67 Chevy 3/4 ton 2WD 402/auto (Business Hauler) 67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC) 68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC) 70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC) 71 Chevy SWB stepside (Crushed by tree - parts donor) 72 Chevy 3/4 ton 4WD (Parts donor) 72 Chevy 3/4 ton 4WD Suburban (Parts Donor) 72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC) 81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler) 82 Camaro Z/28 355/Super T-10 (Pat's toy) 93 Caprice 9C1 (Brian's Cop Car) 02 Toyota Camry (Reliable but a souless steel and plastic hulk) 2011 2SS RS Camaro M6 Factory Hurst Shifter ![]() Maybe I need to sell some of this crap ![]() Yet another Bozo with a sawz-all |
Was just told the truck was sold! Get win
PROJECT 7DEUCE
Sorry to hear that they sold it but there are plenty of these trucks around here...
