Old 05-04-2010, 10:47 AM   #1
LugoMS
LugoMS's Avatar
Help needed
Hello, I am currently overhauling the front end of my '72 pick up and I am having trouble installing the front coil springs. What is the easiest way to install these coils? The truck is a regular 1/2 ton 2 wheel drive. Thanks in advance for the help.
LugoMS is offline   Reply With Quote
Old 05-04-2010, 06:18 PM   #2
mclairmo
Re: Help needed
I always use an inside type coil spring compressor. Harbor Freight sells them for cheap or you can rent them at parts stores. Don't use the two piece outside style.
mclairmo is offline   Reply With Quote
Old 05-04-2010, 06:22 PM   #3
killer71
killer71's Avatar
Re: Help needed
Read this thread as he advises how to do it without a coil spring compressor! Hope this helps!
http://67-72chevytrucks.com/vboard/s...d.php?t=338491
R.I.P.
Killer 71
10/26/07
killer71 is offline   Reply With Quote
