Header Gaskets????
What type of header gasket is the best to run on a 350? I know they sell several different material types of gaskets, I want to buy one that I wont have to replace over and over. Any suggestions???
I wish I was a cowboy
![]() Join Date: Apr 2008
Re: Header Gaskets????
Check out this article. I'm living a nightmare of exhaust leaks...
http://www.chevyhiperformance.com/te...ets/index.html
-Kris Met list: Cyclone,Wilson,TranzAm,extd56,hotrodhomi,mnky30,Rokcrln,Brad,JerryJones(well, his truck anyway). |
Jason
If you are using the headers on a stock cast iron cylinder head I have had the best luck just using the stock manifold gaskets.
WORTHLESS CRUISERS
Ive got headers on mine. The best and cheapest ive found is stock manifold gaskets from a ninetys model. Ive never had a leak and they are easy to get at any local parts store.
Scott Hammond Lancaster, SC 1969 Chevy ![]() If you don't live for something, then you'll die for nothing. www.xclusive-images.com ![]() |
I use the aluminium type and they work great, just be sure to recheck the torque after a couple of heat cycles unless you are using the locking type fasteners.
Tim |
what do I torque the bolts too?
I got some Mr Gasket ultra seal ones from oreillys for $12 and they seem to be working good.
I don't know a certain torque value. Just nice and tight with a wrench by hand (don't try and break them off tight) and remember to recheck them.
Tim |
#9 | |
406 Powered
70 GMC 68 c10 2002 silverado 72 4x4 |
I have always had good luck just using the stoc replacement gaskets. I have doubled them up before also. I usually use some high temp gasket sealer in between them. The one I have the hardest time sealing in the flange at the bottom. I'm seriously considering the flow master weld on clamp together flanges.
*We could learn a lot from crayons... Some are sharp; some are pretty;and some are dull. Some have weird names; and all are different colours;but they all have to live in the same box. * You may be only one person in the world, But you may also be the world to one person. * Some mistakes are too much fun to only make once. Two rules in life. 1. Never sweat the small stuff! 2. Everything is small stuff! |
What?
When I ran headers on the burb, I just used those white Mr Gasket gaskets.
Though what I did is soak them in a pan of water for a day or so, that way when I installed them they had a tiny bit of squish which when dried gave a better seal IMO. As for torque on the header bolts, I just used the German torque value of good n' tight.
Chris 1968 K20 Suburban 1972 K10 LWB PU Last edited by vectorit; 05-04-2010 at 09:04 PM. |
