WTB- Coy Wheel center cap spacers
WTB- A pair of aluminum spacers for the center cap on a Coy C-5 wheels. I have seen several sets that have been made on the board. I have tried to get some made locally with no luck. So if you have a extra set let me know.
Thanks, Steve
1970 Gmc Grande Sierra Swb 2wd LSX (LQ4/4L80e) 1990 K1500 Daily ![]() |
![]() Join Date: Jan 2009
Re: WTB- Coy Wheel center cap spacers
Put me on that list too. I need a set for my front wheels also
Tim |
67-72 parts collector,…
![]() Join Date: Nov 2002
I'll get on the list and I don't even have a set of Coys,... yet.
Ttt
ttt
Guys if i still worked at my previous employer i could hook you up.
I made the 1st set and have the cad file if anyone needs it. just shoot me an email fatboysrodshop@gmail.com |
Still Learning
I have access to CNC machines. I would like to see the cad file and might consider making these for board members if material and shipping is covered.
I have made many parts for members and like to help out when I can. Usually, the biggest problem is finding the time. ![]() |
#8 | |
Man of Mini-Talents
Me too.
Still Learning
I need a drawing or sketch with dimensions and tolerances
WIll the "cad file" from fatboys69 work?
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 05-08-2010 at 08:09 PM. |
Looks like the interest is there for someone willing to make a batch. I'm first in line!
#13 |
Still Learning
I sent him an email to get the cad file from him.
#14 |
mcbassin,
sent you the cad files for the spacers. FATBOYS69 |
#15 |
Still Learning
Okay, I got the file I will take a look at it when I get to work.
#16 |
Still Learning
Does this look like what you are after?
#17 |
Still Learning
I will make a quick program to see how long it will take to make them. It looks like we need .25" (1/4") x 4" X 4" ea. We need to find the cheapest place to buy the stock.
#18 |
put me in for a pair as well pending on price and all.
'71 LWB c10-"WORK" in progress ![]() 385 ci 4 bolt (4.040 bore), scat 6.0" forged h beams,scat forged crank 3.750, speed pro 5cc flat top, clevite bearings, .039 head gaskets,comp xr288hr 110* 288/294adv. 236/242@.50 555/576 lift, pbm hyd roller lifters, chad spiers 215cc imp. heads , comp 1.6 roler rockers, comp magnum push rods, edelbrock victor jr. single plane intake p&p (1206 gasket matched), quickfuel 750R DP , th 350 trans, 5.14 gear, 3000 stall 2012 best 1/8- 7.70 @ 87mph 1.70 60' (lil better) 2013 best 7.39 2014 best-7.38 New for 2013-strange rear coilovers, headman 1-3/4 headers, 5.13 r&p, .060 aluminum bed floor, 15x14 holeshots w/ 31x18.5 hoosier dot pro's, 15x4 holeshots w/ 26x5.5 m/t skinnies and 200+#'s in body weight loss & 6 point cage |
#19 |
That be them ! I made 4 ( one for each wheel ) so that all wheels look the same, but I am just an*l like that. Made mine out of 1/4" aluminum, you will need to get longer mount screws as well. If I remember correctly I got #10-32 x 5/8 Socket Flat Head screws in Stainless steel.
#20 | |
Still Learning
thanks |
#21 |
Still Learning
I did a quick simulation, it looks like about 6-10 minutes to cut them on the mill. Maybe quicker depending how rigid the setup turns out. I will need to make a quick fixture and after that all I need is material. I did find a place to order it online: here
#22 | |
I may have a source for 1/4" aluminum, in small scrap pieces. How big would each piece need to be?
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 05-10-2010 at 05:15 PM. |
#23 |
Still Learning
I was thinking 6061 alum. 4"X4"X.25" thick should be plenty. Let me know what you come up with.
#24 |
Let me look tonight.
#25 |
Man of Mini-Talents
The center caps contact the bearing cap as you tighten the lugs. If you're lucky, the caps will bulge and not break, but even so the gap looks bad.
