Brake lines on 87 chevy c-10
ok i need to know were to find and exploded veiw so i can figure out what part i need. The truck is an 87 chevy c-10 short bed short cab. I need to get the rear brake line cause mine has a leak and help would be great thanks
killed |
Whats this wire for?....
they have a good pic in the LMC catalog, but I don't have a scanner, mabey someone else will scan it for you.
Kyle ![]() '82 C10 Resto-Custom--> * 2 1/4" manifold back dual exhaust with Hooker Aerochambers & High Flow Cats *Taylor Ignition Wires *Centerline 15" Telstars with 32"x10" mudders |
BAD BOW-Silverado XST
killed300ex,
Welcome to the site. Order yourself a free catalogue from www.lmctruck.com. You don't have order anything but pictures in the catalogue are very details. I use it all the time before I take something off or make changes. |
yeller
Year One also has some real good illustrations.
-Jeff |
www.73-87chevytrucks.com
![]() Join Date: Dec 1999
The one connected to the frame in this picture?
http://www.captkaoscustoms.com/images/fuelinebent2.jpg There is only one line running to the back, it has a connector about where the trans crossmember is? If you still have the bed on it will be near impossible to get it installed without bending the line...ALOT I had trouble getting mine is in with just the rear tank in. http://www.inlinetube.com and http://www.classictube.com and http://www.lmctruck.com sell the piece. It will come to your house "coiled". Can you not just splice a new section in there to repair it?
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com |
#6 | |
Trucker.
Well, I requested a longer rear braided line, so I wouldn't think it would be alot of trouble for them. Although they might recommend selling you a coil and you bend it. I know they can make smaller diameter bends, but I haven't asked for a longer line........ yet.. Let me know if you find out.
I have dealt personally with inline tube and was impressed with their service.
#8 | |
Trucker.
I'm gonna do new lines and the P-S-T front end kit soon and install my new idler arm. ![]() |
