Old 05-04-2010, 04:25 PM   #1
blazin
speedo fix after big tires??
i have a problem.. i dont know how to fix my speedo. seem there is no place around anymore (albert canada) that does old school speedo recalibration. im told to change the speed gear in the transfer case. but to what? i have a 700r4, 205 transer and 4.56 gears. thoughts?
blazin is offline   Reply With Quote
Old 05-05-2010, 10:57 AM   #2
milled
milled's Avatar
Re: speedo fix after big tires??
i think napa makes a reducer that attaches to the outside of the t case... If you have a speed odometor shop around you give them a call, those people deal with this stuff all the time.
1970 k20 350 4speed hd44 14b
Circumventing the language filter is against site rules
milled is offline   Reply With Quote
Old 05-05-2010, 03:44 PM   #3
Hoods69BadBowTie
Chevys Kick A$$
Hoods69BadBowTie's Avatar
Yea x2 I have heard about the reducers but never dealt with them myself.
*HOODS is what I answer too*
-'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold
-'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit
-'86 K5 Blazer Silverado 6.2 4" lift 35"s
-'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's
-'83 Monte Carlo T-Tops. 126,500 Original Miles
-LATER
I would rather push a Chevy then drive a ford!!
Hoods69BadBowTie is offline   Reply With Quote
Old 05-05-2010, 06:06 PM   #4
blazin
all the speedo shops have closed down. everything is electronic and the deals do that stuff.
Old 05-05-2010, 06:46 PM   #5
OrrieG
OrrieG's Avatar
Working from memory but when I put the TH350 & 3.74 rearend in my 59 the speedo was off. I ran it for 5 miles at 60 mph speedo reading on the freeway and timed how long it took. should have taken 5 minutes or 300 seconds. I divided the time it took in seconds by 300 and came up with the percentage over or under. I then pulled the plastic gear out of the tranny and took it down to the local Chevy dealership. He had a chart that listed the different colors and difference it changed the output. I got the one that changed it close to what I had calculated installed it and rechecked. Speedo was within 5 seconds for 5 miles so I was happy. This was in 85 so who knows if the current counter guys can help and if GM still makes the different gears. NAPA might have access to the same information too.
When I changed tires to a different diameter it changed again, I just did the test run and just mentally adjusted. I do the same for my Chevelle, I run short tires on mags in the summer, stock tall tires in the winter. Difference is 4 mph at 65.
OrrieG is offline   Reply With Quote
Old 05-05-2010, 10:12 PM   #6
What diameter tires?I here what you are saying.It`s not enough to know you can get reducers at a parts store.You need to know how much you are off first.I found that with 37" tires my speedo was 10% slow.My odometer ran .9 for every mile by the marker`too.This was a 3/4 that would have had 235/85s (7.50-16s) from factory.The first night in town with my new big tires I got a ticket for speeding (figures).I told them I just put the tires on and hadn`t had a chance to figure my speedo difference yet.They offered to go to a road with no traffic and clock me driving by at 25 and they`d tell me what their gun read.So I drove by at close to 40 .They didn`t understand why it was off more than 15 mph,but they let me go.I had a chance to get an accurate reading but was more interested in getting let off on the ticket .I love telling that story! Man,they were stumped.This was in`77 before anyone around my area had tires that big.
Old 05-05-2010, 10:26 PM   #7
blazin
haha great story.. i might have to use that one someday and do the same you did i have 35 inch tires, 700r4 tranny, 205 transfer case, 4.56 gears. one thing i also have a problem with is the length of my speedo cable. the 700r4 is 2 1/2 inchs longer then the 350 that was in there. there was a shop here in town that made cables, hade a dyno in there shop for setup after big tires and gears or whatever. they closed and i cant find anyone that knows about it.
Old 05-06-2010, 01:37 PM   #8
OrrieG
OrrieG's Avatar
The cable I pulled out of my 74 donor was a two piece, main section from the speedo out, then a section about 2' long from the end near the trans to the trans. It was a factory auto so I assumed that it was a factory extension for the 4wd option. Obvioiusly more than the 2.5" you need to make up but an option.
Old 05-06-2010, 05:10 PM   #9
blazin
i ordered a 104 inch cable today, im told it will work. it will be a little to long, but better then no cable now if i could just figure out the speedo gear i need, i'd b set.
Old 05-09-2010, 10:33 PM   #10
1985-GMC
Chevy Enthusiast
1985-GMC's Avatar
This place should have everything you need. http://www.transmissioncenter.net/sp...n_______va.htm
Tony
1985 GMC K2500 restoration Project: Rust, White & Blue
1989 Chevy R3500 CC Cummins & 4X4 swap some day...
1989 Burb (D60, 14BFF, 12V, NV4500, NP205, 37" tires in progress)
1985-GMC is offline   Reply With Quote
Old 05-09-2010, 10:38 PM   #11
msgross
msgross's Avatar
I'd borrow someone with a GPS and check the difference. That's a good website for reference too...
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
