'70 Makes noise when I turn left?
Ok I need help to figure out why my '70 c10 makes a noise when I make a left turn. It sounds like the wheel rubs the wheel well, but it doesn't! I'm thinking it may be the steering? It only makes a noise when turning left, when I make right hand turns its perfect with no noises. Anybody think they know what the problem is? - Thanks!
Chemist under the hood...
Re: '70 Makes noise when I turn left?
As that old doctor joke goes, "Then don't turn left"
Current fleet: 2013 GMC Sierra, 5.3L, 4x4 1988 GMC Sierra, 305, Auto 1984 Jeep Grand Wagoneer, 360 V8 1997 VW Cabrio, 2.0L 2017 Toyota Rav4, 2.5L Stuff I wish I still had: 2013 Toyota Matrix [RIP] 1967 GMC 910 Fleetside, 283 V8 [1st Love-SOLD] 1987 Jeep Cherokee Laredo 4X4, 4.0 I-6 [SOLD} 1994 Chevrolet Caprice Classic, 5.7LV8 [SOLD] 1995 Chevrolet Astro AWD, 4.3L V6 (RIP) 1998 Chevrolet Suburban 4x4, 5.7L V8 [SOLD] |
Have you checked your power steering? Make sure that it is full.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end 1965 Impala SS 400 sbc, Muncie rock crusher 1966 Impala SS 396 bbc, TH 400 1969 El Camino, 350 sbc, TH 350 1971 Snowplow built on a Blazer frame 1972 GMC Short bed, stepside, TH 400, 427 BBC |
Is it lowered with drop spindles? If so check the inside of your wheels and make sure your balancing weights are still there. You may need to do a little work on your lower control arms.
------------------------------------------------- Jim Garage fillers... 85 Chevy C10 Silverado LWB 07 Nissan Altima 2006 Mini Cooper S |
Cops, ha, catch me if you can!
Would like to know what you find, mine has been doing that for a while. Its not lound at all, but like you said it sounds like the tire is rubbing, and mine is still stock(-1"or 2 of almost 40 yrs of sag)
72 C-10 Stepper 350/TH350 3.73 in the back Edelbrock intake and Carb Hooker Comp Headers 275/60R15 on Rallies ![]() ![]() |
Have you checked your wheel bearings to make sure they are adjusted properly
My 67 does the same thing,when i jacked it up i had just a wee little play in my upper a arm bushings on the pass. side.
I had the same noise on my 68 GMC. I read in the manual that if the bearings are worn, when you turn to the side that is worn, they load up and make noise. I changed them out and all the noise stopped. Good luck!
Chevy Lover Till The End.
Check your right side shock, my '69 started doing that and I found my right side shock was bad and had kinda cocked sideways a little but I have a 4"/3" drop with springs only. I replaced all the shocks with drop shocks and it cured my problem.
1969 Chevy SWB Big Block - Under the knife as of 12/26/2011 1989 Chevy Silverado, 4X4 - Daily Driver 1996 Chevy Suburban K1500 - 4-Wheeler, Campin Truck 1968 Chevrolet Impala Sport Coupe - 327/350hp, TH400, all original. Members I've met: BamaBaxter, My Build: http://67-72chevytrucks.com/vboard/s...d.php?t=500359 |
When I first bought my truck it was making a rubbing noise when I turned left. It drove me crazing trying to figure it out. It turned out that my fan shroud was over a little too far to the right, causing the fan to hit the left side when making a turn. Look at your shroud for signs of rubbing. There was very little room for adjustment left to right but it moved enough.
#13 |
I need to check them, that may be the problem! Thanks!
#14 |
Thanks to everyone for thier input! I am going to see if they are the wheel bearings, to see if they are worn or just need proper adjusting. Hopefully thats what it is! Thanks again for all the help!
#15 |
I had the same problem 20 years ago. The mechanic said it was the fat driver putting all the pressure on the left side. It ended up being a tie rod or steering arm rubbing on the tire.
#16 |
#17 |
Anybody have a service manual for a '70 pick up? For the last 2 months I've been trying to find mine but no luck! I think I just need to buy another one!
#18 |
