Old 05-04-2010, 07:09 PM   #1
motiveauto
motiveauto's Avatar
84 Front Suspension Swap
I picked up a suspension from a 84 c10 to drop into my 65 c10. I know a few of you have done this swap before so I had a few questions, here goes: Am I better off swapping over the arms and steering linkage or should I swap the whole crossmember. I have a I6 230ci in there now and the crossmember already has 6 cylinder mounts, will it line up? Has anyone had any luck finding a good set of 6 lug rotors for this setup? Thanks alot guys I appreciate all of your help!
86 K20 6" lift
66 C10 LS2 T56
1947 Ford Rat Rod
Softail Deluxe
Softail Chopper
motiveauto is offline   Reply With Quote
Old 05-04-2010, 07:15 PM   #2
markeb01
Senior Enthusiast
markeb01's Avatar
Re: 84 Front Suspension Swap
Here's a thread that covers the subject and provides recommendations:
http://67-72chevytrucks.com/vboard/s...d.php?t=367260
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502
Old 05-04-2010, 08:43 PM   #3
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
With the engine in place, it's a bit easier to swap just the arms and steering linkage. I've done it both ways over the years. It's a wash in the end, one way requires engine support while crossmember is out of truck, the other requires wrenching those dman u bolts in and out.
If you swap the crossmember, the engine mount holes will line up as they do now. I have an 84 crossmember under my heap so I speak from experience.
Old 05-04-2010, 09:36 PM   #4
Deryl
I did not change the crossmember when I did mine because I didn't see a reason to. I was replacing the control arm bushings anyway so they were coming out anyway. If I had to do it again I would do it the same way.
D's 63
Deryl is offline   Reply With Quote
Old 05-04-2010, 10:43 PM   #5
65Gregg
65Gregg's Avatar
I changed the complete crossmember dust cap to dustcap from an '84 Suburban. It has been in since '01. I don't know if one way is better than the other, it was just my choice. Good luck
65Gregg
Blue long bed
White TBSS
61 Impala
“The two most important days in your life are the day you are born and the day you find out why.” Mark Twain
65Gregg is offline   Reply With Quote
