DiablosWeldingFabrication
Door Gasket Glue
You guys know of any good glue or sealent that works for the door seals and gasket? the last stuff i used from auto zone sucked!
Re: Door Gasket Glue
3M Super Weatherstrip Adhesive 08008 works for me. The trick is to clean the sealing rubber and also clean the area that will be glued...door jamb etc. I think I used lacquer thinner to do that job. You might wipe a little lacquer thinner under your door to make sure it doesn't harm your paint job.
Bob |
#3 | |
60-66 Nut
![]() ![]() Join Date: Mar 2007
Wax and grease remover might be a better choice for cleaning.....less apt to damage the paint.
#4 | |
Bob |
#5 | |
This is what I used and it worked well... |
We use the glue from Motorcraft. You can buy it at the dealer. Its kind of a dark green but sets up fast and works better then Any 3M product . We sell 3M to but use the FORD stuff
