Old 05-04-2010, 10:52 PM   #1
northerngmc
northerngmc's Avatar
Extang Black Max Tonneau Covers
I purchased an Extang Black Max Tonneau Cover for my 68 C20 longbox from Jegs and I am in the process of installing it tonight and I have a question.
This cover has adjustable snaps for different temperatures.
If anyone has one which setting do you use? I am wondering exactly what they mean by warmer and colder? My garage is about 10 C ( 50F) and there is no way it is going on with the tighter setting.
I am thinking it might be because it is still new and needs to work flat after being rolled up in the box. So I have it over the truck box partially in place and if this snow stops and the sun comes out I will pull it out of the garage and let the sun warm it.
Blaine
59 GMC 9314 a.k.a. Whoopee
68 C20 50th Anniversary a.k.a. The Rat
http://www.flickr.com/photos/northerngmc/
http://www.members.tripod.com/P-wee/index_032.htm
1.61803 is one H of a lot better than 3.14159, no really it is!
northerngmc is offline   Reply With Quote
Old 05-05-2010, 08:27 AM   #2
bruceman1968
bruceman1968's Avatar
Re: Extang Black Max Tonneau Covers
Blaine, Its a hot and cold thing. Everything is smaller in cold temperatures. So put it on using the shortest setting. This summer if it sags a little you can flip the snaps and tighten it right up. A brand new cover like that is should be a bear to first strech out even on the small setting Add the cold temp and its harder.
CHEVY/GMC VIN DECODERS
bruceman1968 is offline   Reply With Quote
Old 05-05-2010, 08:43 AM   #3
Shane
Shane's Avatar
stretch the cover out and lay it out in the sun before trying to install it ... helps it to be more pliable.
this trick also works with new carpet out of the box to help it lay flat
Shane is offline   Reply With Quote
Old 05-05-2010, 10:06 AM   #4
northerngmc
Thanks guys,
Yeah I get the colder equals smaller, I thought 50F should not be COLD!
-8 C or about 20F outside right now, but sunny.
Blaine
Old 05-05-2010, 10:12 AM   #5
Hottrucks
Redefining LowBudget
Hottrucks's Avatar
with my extang I got on about as much as I could with it warm...then I took a 5 gallon pail with hot water and poured some on you have to work kinda fast but it does work once you get it on pour the rest of the water on it to help it settle in...
1970 C10 CST fleetside 472 ....big dreams little cash...
SunShine Syndicate..
Mikes Sandwich Fair Run OCT 8th 2011
Hottrucks is offline   Reply With Quote
Old 05-05-2010, 10:09 PM   #6
northerngmc
Well it is on.
I set all the rail snaps to the loose setting and still couldn't get it. So out came the heat gun and I gently warmed sections of it while pulling and it is on.
Blaine
Old 05-05-2010, 10:12 PM   #7
QKENUF4U
QKENUF4U's Avatar
LOVED MY EXTANG COVERS.. i used the ones that work like a tupperware lid... they where a biatch in the winter but man once on they worked awesome.....
QKENUF4U is offline   Reply With Quote
