Old 05-04-2010, 10:57 PM   #1
1972trucks
A new guy cutting factory ac holes in dash
With some practice and encouragement from some friends i have decided to put air on my truck. I was worried because i have spent so much time on it and its already painted just not put back together yet so i figured do it know. I used templates out of a factory air dash and practiced on a rusty cab i have. Thanks to Jerry Brown and Jason at the Truck Shop for encouraging me to do it. I also wanted to say this a great board to learn stuff and I enjoy it i look at everyday.
Morgan
1972trucks is offline   Reply With Quote
Old 05-04-2010, 11:18 PM   #2
big mike71
big mike71's Avatar
Re: A new guy cutting factory ac holes in dash
Dude, The first thing you have to learn from this site is to post pics. Somebody show him the sign because I don't know how.
I'm not as good as I once was, But I'm as good once as I ever was.
big mike71 is offline   Reply With Quote
Old 05-04-2010, 11:32 PM   #3
1972trucks
I will have to put some pics up tommorow when i get home
Old 05-04-2010, 11:36 PM   #4
71blksuper4x4
SWB 4x4 Collector
71blksuper4x4's Avatar
Are you going with factory air? Did you cut the firewall as well?
TREVOR
1970 CST swb 4x4 (speedwarning,cruise,tilt,tach,8track, original red shoulder belts,tow hooks)
1972 Jimmy (soon to be Hickey cloned)
1971 Cheyenne Super 4x4 swb (tilt,tach,buckets, original blue shoulder belts,am/fm,cruise,tow hooks, dealer 8 track)
1972 Cheyenne Super K20 4x4 Custom Camper (tilt, tach, am/fm, tow hooks, bed toolbox, aux gas tank
1972 Cheyenne Super Crew Cab K30 4x4 Duramax, Allison, np205, buckets, tow hooks (CURRENT PROJECT)
http://67-72chevytrucks.com/vboard/s...d.php?t=624819
1989 V3500 Crew Cab (454tbi, NV4500, np205)
1970 Chevelle SS (LS5 454,th400,8track,buckets,tach)
:2004 Jeep Wrangler Rubicon (daily driver)
WTB: 1968-70 Cruise Control Lever
71blksuper4x4 is offline   Reply With Quote
Old 05-04-2010, 11:59 PM   #5
1972trucks
Yes im going with factory air and i havent got to the firewall yet but i have plenty of parts trucks with air so im going to make the firewall the same as an air cab just been busy and cutting holes in a painted dash is really time consuming
Old 05-05-2010, 12:15 AM   #6
71blksuper4x4
SWB 4x4 Collector
I wasn't being rude, just making sure that they did tell you about the firewall difference. Sounds like you got it down. Trevor
TREVOR
Old 05-05-2010, 12:18 AM   #7
MT1972cheyenne
MT1972cheyenne's Avatar
Big Mike71, Here you go:
MT1972cheyenne is offline   Reply With Quote
Old 05-05-2010, 12:21 AM   #8
ksbrktracer
TNT-MOTORSPORTS
ksbrktracer's Avatar
I'll do it.....................
ksbrktracer is offline   Reply With Quote
Old 05-05-2010, 12:22 AM   #9
ksbrktracer
TNT-MOTORSPORTS
ha ha.....make sure to post them.............
Old 05-05-2010, 12:37 AM   #10
oldmanlance
oldmanlance's Avatar
ive done this to a couple of trucks its not to bad , i cut out the outlets from an old dash kinda made templets like worked real good.
oldmanlance is offline   Reply With Quote
Old 05-05-2010, 01:05 AM   #11
72lb4x4
Anybody want to suggest how or what tool to use to cut the holes? I hope to do this someday...
72lb4x4 is offline   Reply With Quote
Old 05-05-2010, 06:28 PM   #12
1972trucks
the easiest thing i know to do for the round holes is to mark the hole really good with a marker and drill around the edges of the hole. I knocked the piece out and took my cutoff wheel with a round grinding stone and cleaned the burrs off the edges. The center vent i took the cutoff wheel and cut it but if somebody has any better ways to do it im willing to try it. I will get pics of one hole i have finished tonight.
Old 05-05-2010, 06:45 PM   #13
Old Yeller 1970
DON'T TREAD ON ME
Old Yeller 1970's Avatar
My suggestion would be to use a good quality correct diameter hole saw. They work best with a low speed drill, typically a bigger half inch drill as opposed to the smaller faster 3/8" drills. Add some cutting oil and you can make a very clean hole in a few minutes. I haven't ever done this on a dash but I've cut through similar gauged material many times with good success.
Old Yeller
Old Yeller 1970 is offline   Reply With Quote
Old 05-05-2010, 08:30 PM   #14
gkesseru
gkesseru's Avatar
Other option is to use a carbide burr mounted in a die grinder. My welding supply store carries them.
72 Fleet (died)
78 Step (sold)
55 Step named Fred (sold)
00 F150
68 Step (named El Scorcho by PO)
Build thread for the new El Scorcho http://67-72chevytrucks.com/vboard/s...d.php?t=392932
gkesseru is offline   Reply With Quote
Old 05-05-2010, 08:54 PM   #15
bigsnookmaster
bigsnookmaster's Avatar
I've done it, and it's really not too bad. I drilled a smaller hole and worked to it with a carbide burr. Tape everything up first though, and Don't be Scared! Lol. Good luck!
bigsnookmaster is offline   Reply With Quote
Old 05-05-2010, 11:22 PM   #16
1972trucks
heres a pic of the driver side vent im still working on the center vent.Name:  orange truck 011.jpg
Name:  orange truck 012.jpg
Old 05-05-2010, 11:35 PM   #17
Newtz67
Newtz67's Avatar
Looking good!
Newtz67 is offline   Reply With Quote
