drag it like you stole it
ashtray?
are ashtrays different trough the years? i have one but it wont fit in my 72 dash. i took it out of either a 69,70, or 71 (didn't pay attention? OR is it just hard to get in?
negative camber //LA\\ |
im pretty sure they are all the same. if not im sure you could grab a sledge hammer and MAKE it fit
Brandon, SD 69 GMC 1/2 ton 2wd wide long bed with wood 3 on the tree 350 engine 4 bolt main rv cam AIM = Alphray04 |
I have heard that 67-8 are diffirent ? Not sure
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
![]() Join Date: May 2001
The early years have ball bearings ( or something like that ) and the later ones just have plastic to slide on. I have a truck of every year out here, I can look tomorrow and see what year changed.
72 3/4t Custom Deluxe 402/auto 66k Original paint 71 3/4t 4x4 Custom Deluxe 10k original miles Original paint 71 3/4t Cheyenne 402 70k original paint 72 3/4t 4x4 Custom deluxe 72 3/4t 4x4 Custom deluxe 91k original paint 72 Cheyenne/30 Dually 69 Camaro SS396 4-speed 13 GMC 2500HD Duramax I bought new 05 Jeep Wrangler "Willys Edition" 12k miles (I bought new) 85 3/4 ton 4x4 Scottsdale 33k miles original paint 86 1 ton 4x4 SRW Silverado 454 restored 80 1 ton 4x4 SRW Silverado 9,434 original miles!! original paint 95 GMC 1 ton dually 4x4 my dad bought new 95 GMC 3/4 ton 4x4, regular cab 454, 31k original miles 2002 2500HD 4x4 regular cab 6.0L 67k miles 2002 2500HD 4x4 regular cab 8.1L 28k miles 2003 GMC 2500HD 4x4 regular cab Diesel 93k miles 67-72 Parts for sale |
Yes the 67-68 are different than the 69-72...
its all about the +6 inches
lunatic has it right.
Ball bearings (one large one per side) on 68 and older, and nylon/plastic bushings on 69 and up. I have however seen a couple 72s with an odd set up...I can't remember what was up with them, but I'll try to see if I can find one/pic of one/remember what is up with the couple I've seen. |
