Back in the sticks
Adding Aux Battery
Ok, I got my Aux Battery tray from Scotts Super Trucks, Thanks Scott!!
Now how do I bolt this thing in? There is one bolt hole that is already threaded on the support, but seems like the others will have to be added. Has anyone retro-fitted one yet? Pics would be awesome! I'll post a pic of the tray tonight, its a monster! Heavy duty metal construction was used throughout.
1971 Cheyenne C-10 w/700R4 and Tuned Port Injection 1969 K5 Blazer w/Tuned Port 2010 2SS/RS Flaming Orange Camaro 2011 K1500 Suburban 2014 K1500 Pickup 2008 Nissan Altima? The wifes' hoopty |
![]() Join Date: Mar 2003
Re: Adding Aux Battery
Lay the tray in and mark the holes. Drill. Bolt in tray. Don't forget to move the horn and voltage regulator
pics? Never seen one
Back in the sticks
First the Aux tray
Back in the sticks
Now the regular one
#6 | |
Back in the sticks
Thanks for the help!
Redefining LowBudget
sub scribed
1970 C10 CST fleetside 472 ....big dreams little cash... SunShine Syndicate.. ![]() Mikes Sandwich Fair Run OCT 8th 2011
Recovering 67-72 Addict
![]() Join Date: Oct 2000
Here is a not so great pic that I took of a factory installed setup. I took it to help myself during the reassembly process.
68 Short Fleet 4x4; 427; BTO Level 3 700R4; NP205; Dana 60 front and rear; 4" lift with 35's; Disc brakes; AGR variable ratio steering; factory bucket seats; factory tach and tilt. "Friends call me cruzer cuz I like fast cars and fast women" |
![]() Join Date: Oct 2009
Yep mark the holes and go. If your lucky, you won't have to move anything. I recommend the Hellroaring solid state unit, it's a bit pricey but it's the best out there. I have a thread 2nd battery hook up question (Electrical). There are pics. I went 2 ga wire on all Pos wire
Back in the sticks
Thanks Breeh, that helps a bit. I was wondering how it got past the headlight. Right now if I lay it in there it is pulling on the wiring harness. Will have to do some more in depth fitting before I drill and mount.
its all about the +6 inches
they weren't all done the same. My voltage reg was mounted on the other 'leg' in my longhorn, and on the other aux tray I have laying around.
Back in the sticks
Ya, I just pulled Shifty's old post out of my PM box and realized he told you how to do it. There are pre-drilled holes on the side of the aux box for the regulator and there'll be a half inch spacer required behind the headlights.
How you been Andy? Haven't seen you around in a while.
#13 |
I've been great... just had a son born on monday.
Kinda funny you haven't seen me around much... I'm still here postin like crazy. ![]() |
#14 |
Back in the sticks
Congrats!! You may be right, maybe it is me that hasn't been around much...
#15 |
#16 |
hey red, check the height with the battery installed, mine looked higher then the pass. side, but don't know! I have since pulled my front end off again so I can't measure it. I think I used one or two factory holes and the rest I had to drill
I'll probably use side posts to give more clearance, lmk how you wire it up congrats. LHM
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 05-07-2010 at 01:25 PM. |
#17 |
the Aux tray does in fact sit higher. Since top posts were used till the end of 70, I would say there is no worry on the taller 69 - 72 hood. However, I don't think the option was around in 67 or 68, so top post clearance MIGHT be an issue, but I doubt it.
Side posts are better in almost every way anyways. |
#18 |
Back in the sticks
Hmm, well, I think that my core support may have had an aux battery before it came to me. Thanks Livrat!! 3 of the bolt holes were already there and threaded so it just mounted right up. I'll see about getting the 4th bolt in later.
#19 | |
Back in the sticks
#20 | |
Back in the sticks
