Old 02-11-2003, 01:01 AM   #1
xam
1969 c30 wheels
Has any one out there found a replacement for the 69 c30 split ring wheels? 8 lugs with 1/2" wheel studs . I have a set of 17 1/2" , but i am looking to run 16". Thanks for your thoughts.
xam is offline   Reply With Quote
Old 02-11-2003, 01:14 AM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Welcome to the board xam.
Pretty much any 16 inch 8 lug rim will bolt on.
Try to avoid the 16.5 as the tires are very expensive and a smaller selection compaired to the 16 inch.
Be sure to throw away the old dangerous junk rims away....far far away.
Old 02-11-2003, 01:53 AM   #3
xam
wheels
New style 1971 and up you Know late model stuff, all have 9/16" wheel studs the 1970 and earlier have 1/2 " . not a huge problem with standard style acorn nuts on the front ,but lots of slop on the dual rear wheels. Thanks for the welcome.
Old 02-11-2003, 11:42 PM   #4
Longhorn Man
You ARE right, and I should have mentioned that.
I have run the 9/16 rims on 1/2 inch studs with no problem...but never a daulie though.
Old 02-12-2003, 12:12 AM   #5
da-burb
"Ochre Ogre"
da-burb's Avatar
The lugs on my 71 and 72 C30's are flat, not acorn/tapered. Is that something that changed for 71+?
I think your safest bet is to press out your current studs and drill for 1/2". Then get the 16" rims that fit correctly on the hubs since the C30's are hub centric.
Bowtie Truck Stop Inc.
Mid-West GM Truck Restoration Parts Supplier
Your Key Parts, Auto Metal Direct, Dynacorn,
and Goodmark dealer.
like us @ www.facebook.com/BowtieTruckStop
1971 C-10 Suburban (Ochre)
1971 K-10 Suburban (Ochre)
1972 C-10 Suburban (Ochre)
1972 K-20 Suburban (Yellow- that just aint right!)
Springfield, Minnesota 56087
da-burb is offline   Reply With Quote
Old 02-12-2003, 12:33 AM   #6
xam
c 30 wheels
I also have flat lugs on my c-30. Can I just press out theoem 1/2 " studs , drill to the correct size and press in 9/16 " studs ?? Sounds correct but I have never tried it.
Old 02-12-2003, 11:55 AM   #7
Joesjunk
Joesjunk's Avatar
I took out all of the 1/2" lug studs on my black68 1ton dually and redrilled them for 9/16" lugs. I had to get longer studs to put alcoa aluminum wheels on it. The front ones are easy, the rear drums are more of a challenge. Good luck, Joe
72 3/4t Custom Deluxe 402/auto 66k Original paint
71 3/4t 4x4 Custom Deluxe 10k original miles Original paint
71 3/4t Cheyenne 402 70k original paint
72 3/4t 4x4 Custom deluxe
72 3/4t 4x4 Custom deluxe 91k original paint
72 Cheyenne/30 Dually
69 Camaro SS396 4-speed
13 GMC 2500HD Duramax I bought new
05 Jeep Wrangler "Willys Edition" 12k miles (I bought new)
85 3/4 ton 4x4 Scottsdale 33k miles original paint
86 1 ton 4x4 SRW Silverado 454 restored
80 1 ton 4x4 SRW Silverado 9,434 original miles!! original paint
95 GMC 1 ton dually 4x4 my dad bought new
95 GMC 3/4 ton 4x4, regular cab 454, 31k original miles
2002 2500HD 4x4 regular cab 6.0L 67k miles
2002 2500HD 4x4 regular cab 8.1L 28k miles
2003 GMC 2500HD 4x4 regular cab Diesel 93k miles
67-72 Parts for sale
Joesjunk is offline   Reply With Quote
Old 02-12-2003, 12:50 PM   #8
Rod
I had trouble finding those flat dually nuts for 71-72 but now I have ten extras...NOS in NOS Box.. will see for what they cost me. Rod They look liike this one... but this pic is of the used ones I took off so people knew what I was looking for back when I posted for them.
Senior active founding member.
70 3/4 ton GMC Suburban 4x4 250/4 spd.
71 1/2 ton Suburban Chevy 4x4, 350/350
72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane
2005 FLSTSCI Harley Springer
85 FXSB Harley Lowrider
72 Triumph 650 Bonneville 5spd
"Poor people don't have hobbies" Quote from wife.
Rod is offline   Reply With Quote
