Old 05-05-2010, 06:56 PM   #1
John Pasinski
John Pasinski's Avatar
Oil filter question
This is an odd question. I have '72 C30 402cid. I work her alot haulin scrap. The standard oil filter is too difficult to R/R because it's only 6". It gets lost up inside the filter cavity. I want to install a commercial type filter. The type that holds 2 qts. of oil. Like a Baldwin or Fleet brand. Does anyone know what the stock number is for a filter to fit this engine? Thanks.........
A man's thoughts devise his ways; but it's GOD that directs his steps.
John Pasinski is offline   Reply With Quote
Old 05-05-2010, 08:15 PM   #2
junkyardjohn
junkyardjohn's Avatar
Re: Oil filter question
I ALWAYS LIKE TO USE THE WIX 2 QT. FILTERS ON ALL OF MY MOTORS. I'M NOT SURE OF THE PT.# , BUT WIX MAKES THE NAPA GOLD SERIES FILTERS ALSO. THE BAD NEWS IS THAT THEY COST ABOUT $12 INSTEAD OF THE $2.99 FRAM FILTERS AT WALMART. (YOU NEVER SEEM TO GET MORE THAN YOU PAY FOR WITH FILTERS) CUT A COUPLE OF THE CHEAP ONES APART WITH A PIPE CUTTER & THEN A WIX FILTER & DECIDE FOR YOURSELF. I'LL BET YOU NEVER USE ONE AGAIN. YOU'LL NEVER WEAR OUT THE OIL IN YOUR MOTOR, IT JUST GETS CONTAMINATED & DIRTY WITH CARBON. CLEAN OIL IS VERY VERY IMPORTANT TO AN ENGINES LONGEVITY. IT KEEPS ALL THOSE LITTLE PARTS SLIDING OFF OF EACH OTHER. JOHN
junkyardjohn
69 1 TON TOW TRUCK //
84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. THERES ROOM FOR ALL OF GODS CREATURES RIGHT NEXT TO MY MASHED POTATOES//
LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS)
DON'T RENT U-HAUL
ALWAYS TELL THE TRUTH
IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST
junkyardjohn is offline   Reply With Quote
Old 05-06-2010, 03:38 AM   #3
John Pasinski
Thanks for taking the time to answer my question John. I'll do a search for Wix filters. I'm sure I'll be able to come up with a part #. Yeah you're correct about getting what you pay for. In order for mfg's. to get their products into volumn sellers like Wal-Mart, they MUST get their wholesale price down. Consequently, they have to find a way to lower the cost. The easiest way is by LOWERING THE QUALITY of the stock sold to a retailer such as Wal-Mart. That way they are able to make their mfg'ing margins and sell in volumn. I worked for a large tire mfg. years ago. That's exactly how it worked. That same brand tire was mfg'd. to differing quality standards depending on which retailer was purchasing it. ALL same brand products are NOT the same.
Old 05-06-2010, 07:32 AM   #4
NINERS1
NINERS1's Avatar
here is a great write-up on oil filters by an independent source, it says[as i have heard] stay away from fram!
http://minimopar.knizefamily.net/oil.../opinions.html
71 chevy cheyenne lwb
http://s321.photobucket.com/albums/n..._tab_my_albums
Democracy is two wolves and a lamb voting on what to have for lunch. Liberty is a well-armed lamb contesting the vote!
NINERS1 is offline   Reply With Quote
Old 05-06-2010, 09:24 AM   #5
junkyardjohn
JOHN.. IF YOU GO TO NAPA & EXPLAIN WHAT YOU WANT (JUST TELL EM YOU WANT A NAPA GOLD 2 QT. FILTER FOR A PRE 86 V-8 CHEVY) THEY'LL KNOW EXACTLY WHAT YOU WANT. (NO 19 YEAR NO NOTHING KID THAT CAN'T FIND YOUR APPLICATION IN THE COMPUTER) I'VE FOUND THAT EVEN THE WORST NAPA STORES HAVE COUNTER PEOPLE WITH AT LEAST SOME KNOWLEDGE OF PARTS. JOHN
junkyardjohn
DON'T RENT U-HAUL
Old 05-06-2010, 12:50 PM   #6
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
some napas even have a fram verses napa gold filter cut up example in a plastic case.
I did this myself quite a few years ago and was amazed at the lack of quality inside a fram.
Old 05-06-2010, 04:26 PM   #7
hayhauler71
hayhauler71's Avatar
Fram ph373 or Purolater L40084 are 2 qt filters that will work
hayhauler71 is offline   Reply With Quote
Old 05-06-2010, 04:32 PM   #8
piecesparts
Parts and more parts
piecesparts's Avatar
I purchase my oil filters from NAPA, but I purchase them when the company runs a filter sale (Which is twice a year in my area). That puts the price in line with those Wallymort prices on the others and I have them in stock on my shelf,so I can change oil anytime that I want.
Frank
piecesparts is offline   Reply With Quote
Old 05-06-2010, 07:26 PM   #9
John Pasinski
Thanks EVERYONE! I found a site: fleetfilter.com (sorry I can't figure out how to add hypertext). Anyway; on there they took many different brand filters and cut them open and compared them to the NAPA gold (made by Wix). Very interesting data. Yep.....ya git what ya pay for.
Old 05-06-2010, 07:50 PM   #10
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Highlight the address, click Edit and then click Copy.
Then in your post, click Edit and then click Paste.
http://www.fleetfilter.com/
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is offline   Reply With Quote
Old 05-06-2010, 07:51 PM   #11
John Pasinski
Thank-you!!
Old 05-06-2010, 08:07 PM   #12
Longhorn Man
fram is like a kleenex tossed in a metal canister.
No... make that a generic facial tissue
Old 05-06-2010, 11:07 PM   #13
tlandmark
the NAPA number for a 2 quart is 1794.
tlandmark is offline   Reply With Quote
Old 05-07-2010, 12:17 AM   #14
mclairmo
Fram stuff used to be good, now it all sucks.
mclairmo is offline   Reply With Quote
Old 05-07-2010, 12:35 AM   #15
raverider
1060 , 1062 is what a lot of the bb's run for wix, well napa wix numbers same thing without a 4 in front of them.
raverider is offline   Reply With Quote
Old 05-07-2010, 12:36 AM   #16
raverider
hey i worked there when i was 19, and i could have found the 2 quarter
Old 05-07-2010, 09:03 AM   #17
junkyardjohn
NO OFFENCE INTENDED. YOU ARE PROBABLY THE EXCEPTION. USSUALLY WHEN A COUNTER KID IS LOOKING FOR ONE OF MY TRUCKS IN HIS COMPUTER I SAY... IT'S BLUE.. IF THAT HELPS. I DON'T HAVE MUCH USE FOR MOST OF THE COOKIE CUTTER PARTS CHAIN STORES UNLESS I NEED A COUPLE OF GALLONS OF OIL OR ANTI-FREEZE. & THEN I BETTER KNOW EXZACTLY WHAT I NEED. JOHN
junkyardjohn
DON'T RENT U-HAUL
Old 05-07-2010, 09:23 PM   #18
kcfirstbuild
John, I totally agree with you on cutting the filters open. I work At a parts house and we Sell Wix and as soon as we cut open a AC Delco, Fram and a Wix. More people have been buying Wix. I wouldnt put a Fram Filter on my sisters car.
kcfirstbuild is offline   Reply With Quote
