Old 05-05-2010, 07:00 PM   #1
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
QUICK! Whats diff. between delco/bendix brake boosters?
My booster went bad, it was off a 71 or 72 its the thinner style, is it delco or bendix? thanks
guy said one was adonized gold and other was black
John
1999 Toyota Tacoma 4x4
Old 05-05-2010, 07:43 PM   #2
oldblue1968chevy
Re: QUICK! Whats diff. between delco/bendix brake boosters?
anyone know? i need a new one and parts store cant tell me, id like to order it tonite so I can pick it up tomorow after school (scary with no power brakeslol)
John
Old 05-05-2010, 07:50 PM   #3
HOGDADDY
HOGDADDY's Avatar
The anodized is more like the oem I would imagine but if Bendix is cheaper and it doesn't matter to you then go with cheaper one imho,
HOGDADDY is offline   Reply With Quote
Old 05-05-2010, 07:51 PM   #4
john
member #16
john's Avatar
For one the holes on the booster bracket are different centers. My 1/2 ton used the delco unit. The bendix booster wouldn't bolt on.
john is offline   Reply With Quote
Old 05-05-2010, 07:58 PM   #5
oldblue1968chevy
the arrow shows where its leaking
this is the best pic I got
John
Old 05-05-2010, 07:59 PM   #6
oldblue1968chevy
Its from a 71 gmc 1/2 ton probably original if that matters
John
Old 05-05-2010, 09:07 PM   #7
71 super
71 super's Avatar
The bendix is painted black from the factory and delco was anodized. The your pics look to be the delco unit, bendix units are more smooth and each will have either delco-moraine stamped on the case or bendix stamped around the perimeter. The master cylinder for bendix units is typically a single bail unit and the delco type uses a dual bail type m/c and they will interchange with each other. They are the same thickness also, same operation different manufacturer, same brackets etc.
67 blue step side- bb
68 gold and white swb cst anniversary
68 custom swb hot rod Ls swap
69 swb cst 6 cylinder/ overdrive
69 black/black cst bb swb
70 orange and white cst Canada built truck swb bb
71 black and white super swb bb
71 red and white super swb
72 green and white super swb 4x4
62 nova wagon 400 series Ls swapped
68 Camaro 327/4 speed- 1 owner, original paint
66 Volkswagen bettle
69 auto stick Volkswagen Beetle
71 super is offline   Reply With Quote
Old 05-05-2010, 10:01 PM   #8
Bob B.
Rule of thumb, Bendix boosers were used '67-'70 on drum brake trucks, Delco-Moraine boosters were used '71-'72 on disc brake trucks. Usually, a 1/2 ton truck would use a single diaphragm booster, a 3/4 or 1 ton would use a dual diaphragm booster. That holds true for both Bendix and Delco-Moraine boosters. I would disagree that they are interchangeable. As John pointed out, the mounting studs are on different centers, and the length of the booster pushrod is different too. Using the wrong booster can result in no brakes, so be careful.
1967 GMC CM-2500 Camper Cruiser, 351E V-6, NP 435 4 speed, Dana 60, and factory A/C. 2012 GMC K-3500 WT regular cab, 6.0L Vortec, 6L90.
Bob B. is offline   Reply With Quote
Old 05-05-2010, 11:29 PM   #9
oldblue1968chevy
So I would have a delco?
John
