Old 02-11-2003, 01:25 AM   #1
Ali-N-Cali
1970 chevy truck....feels like rear end trying to pass me up!!
I recently purchesed a 1970 CST 10 Truck.........It feels at times that the rear of the truck wants to pass me!! Is this a frame problem or something else....
Ali-N-Cali is offline   Reply With Quote
Old 02-11-2003, 07:42 PM   #2
71Seth
71Seth's Avatar
when???? There are alot of very sharp guys on these boards and I have learned the more info you give out the better they can help! So let us know alittle more.. Good luck
Also found that you get alot more veiws in the 67-72 board.
97 ext cab 4x4
04 pontiac grand am
05 honda rancher AT (yellow)
71' C-10 swb sb400 th350 .040, 292 Mag comp cam, high rise Edelbrock w/750 duel feed Holley, Accel super coil and wires, B&M ratchet shifter
71Seth is offline   Reply With Quote
Old 02-11-2003, 07:52 PM   #3
crazy longhorn
Fabricate till you "puke"
A good place to look would be at the bushings in the rear control arms & track locator bar. If these are shot , it will let the rear diff wander around under the truck.....crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 02-13-2003, 10:02 PM   #4
cdowns
cdowns's Avatar
another thing that will give you that feeling is a bent frame
