Old 05-06-2010, 12:06 AM   #1
72tutone
72 PRNDL gear shift issue
My 72 truck I have to move it down to almost L1 L2 for it to fully engage to Drive.. So if you were to move it up to D the handle falls down... Is this a clip issue, or something lower on the transmission?
Also is there away I can fix where I dont have to jam it up into park? I have to use some force to get it up into park.
72tutone is offline   Reply With Quote
Old 05-06-2010, 07:09 AM   #2
OhioDan
OhioDan's Avatar
Thumbs up Re: 72 PRNDL gear shift issue
Sounds like ya need to adjust yer shift linkage? Block wheels, set park brake. Check linkage where shift linkage connects to column for worn bushing or link arm. Repair as needed. Loosen nut on linkage at base of steer column where shift linkage connects to column. Put trans into park or neutral, no matter what it says at indicator. Have someone hold shifter into whatever gear your trans is in, and tighten adj. nut. May have to repeat as necessary until ya get it right. Hope this helps?
LIFE AIN'T EASY WHEN YER FAT AND GREASY!
GMC= Got More Class!
1970 GMC LWB, Fleetside, 350/4spd, Flowmaster "40's", 2002 GMC 16" Rallies, cowl hood,and added a bunch of options that weren't there when I started.
OhioDan is offline   Reply With Quote
Old 05-07-2010, 06:14 PM   #3
72tutone
I kind of know what your taking about. Today I looked at it. Now at the top where there is a nut to the linkage it appears that there is like a fan that when you shift, the lever goes down. Those "fan blades" however you want to call them look worn.
Could this be the problem?
Old 05-07-2010, 11:08 PM   #4
72tutone
ttt
Old 05-08-2010, 05:25 AM   #5
OhioDan
OhioDan's Avatar
pics????
Old 05-08-2010, 11:27 AM   #6
Classic Heartbeat
Project Junkie! Fishing Poor!!
Classic Heartbeat's Avatar
I would have someone shift the truck (with it turned off of coarse) and watch the adjuster to see if it is slipping on the shift rod. If so, tighten the 9/16 bolt once you adjust it. If not the it sounds like you may have lost the rubber grommet and steel sleeve out of the shift arm at the bottom of the column. You may also have worn linkage issues. If the first thing doesn't solve your problem, then you will need to take it apart to inspect for ware. WES
On-line catolog
Classic Heartbeat Pickup Parts
WEHEPP@comcast.net
Call us Toll Free (888) 338-2502
Like Us on Facebook
No appointment necessary.
72 BB Chevy Custom Deluxe / Custom Camper
67 I-6 (Soon to be 5.7 LS1) Panel
68 BB Chevy Short Bed
72 6.0 LQ9 Short Bed Chevy 4X4
Olympia's fastest growing truck parts supplier.
Olympia's home for Wayward Chevys
Classic Heartbeat is offline   Reply With Quote
Old 05-10-2010, 09:41 AM   #7
72tutone
Here are some pics that are requested. The nut where the circle is at, I have tightened that as much as I could. The problem still persists. The arrow points to the part in question. This appears to be worn. I am not even sure what that part is called. I hope someone could shed some light on this.
Old 05-10-2010, 11:33 AM   #8
OhioDan
OhioDan's Avatar
Not real sure, as I have a 4 spd., but I think that the detent just below the nut is supposed to go in between the fingers on the lower lever you're pointing to. I think that is what activates your backup lights and nuetral safety switch? Wish I could help more.
Dan
Old 05-10-2010, 11:36 AM   #9
72tutone
Yes that is correct. That is what it does. What happening is its sliding down which engages the gear, but its not staying put. That is why I am thinking its worn. If that is the case, I dont even know what part I should be looking to replace is called.
Thanks for the help though.
Old 05-10-2010, 10:11 PM   #10
72tutone
ttt
Old 05-10-2010, 10:21 PM   #11
OhioDan
OhioDan's Avatar
IIRC, you should have to pull your shifter back toward you, in order to shift out of park? When you do, does anything move at your adjustment point on the linkage? Forward or backwards? Maybe, you have a broken ball off the end of your shift arm on the column? Mighy want to check it out? Please, someone more knowledgeable chime in. I don't own an auto shift.
Old 05-11-2010, 07:52 AM   #12
72tutone
Yes when you move the shifter arm down, it goes into r, n then drive etc... However what is happening is on the column that piece moves down but it doesnt "engage" so to speak. Its real sloppy and loose.
Old 05-11-2010, 08:02 AM   #13
chevy88
chevy88's Avatar
GO to this to adjust and tighten up, it might help on post #8
http://67-72chevytrucks.com/vboard/s...18#post3959618
Kerry
My build thread.
http://67-72chevytrucks.com/vboard/s....php?p=3657823
1971 Chev SWB with 68 nose, 6.2 diesel th350, and 3.73 rear gears
1988 Chev Extendacab
2010 Honda VT1300CS Sabre
2005 Buick Rendezvous wife's ride
chevy88 is offline   Reply With Quote
Old 05-12-2010, 08:59 AM   #14
72tutone
Well I managed to do that now the holes where the screws were arent lining up... Its like the holes somehow have drifted up a bit, and I cant find anything to move them back down. I tried sticking something in the hole to push it downward to line up with the bracket and screw, however Im having no such luck.
Has anyone ever experienced this before?
Old 05-12-2010, 09:33 AM   #15
chevy88
chevy88's Avatar
Do not stick anything in holes/be careful you could ruin threads. Try turning outside with pipe wrench and hold inner shaft crescent/visegrip to take out play. Lets us know how it turns out.
Kerry
My build thread.
