Old 05-06-2010, 11:43 AM   #1
D-Rat
D-Rat's Avatar
More AC questions
Does the AC compressor run if the fan is on regardless of where the middle slider is set? I turn on my fan, and even if the slider isn't all the way over to the "AC" position, and my idle drops significantly.
I'm trying to figure out why.
1970 CST with a screaming 400
www.nissan4wheelers.com
D-Rat is offline   Reply With Quote
Old 05-06-2010, 11:50 AM   #2
leddzepp
Moderator
leddzepp's Avatar
Re: More AC questions
No, it shouldn't run when the top slider is to the right (this is the one that turns the compressor on/off). Watch and see if the clutch engages while someone turns it on in the cab.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
leddzepp is offline   Reply With Quote
Old 05-06-2010, 03:17 PM   #3
D-Rat
D-Rat's Avatar
I'll check that then. Can you think of any other reason my idle would drop when I turn on the fan? I can't imagine that drawing that many amps...
