05-06-2010, 12:36 PM | #1 |
LS ecu mounting in 67-72?
Hey guys,
Where did you mount your ecu? Please post pics if you have them. David |
05-06-2010, 03:20 PM | #2 |
Kill Bill...et
Re: LS ecu mounting in 67-72?
Passenger side kick panel and built kick panel covers for it. Will post pics when I get home.
05-07-2010, 02:00 AM | #3 |
Always wrenching!!
71 C-10 5.3L/4L60E 72 Camaro LS6/4L60E 06 Duramax 19 RZR XP4 turbo Dynamix 56 Belair 5.3/4L60E swap in progress |
05-07-2010, 06:51 AM | #4 |
Under the seat...
07-08-2012, 01:56 PM | #5 |
A day late and $1 short...
Lets bump this up to find out if there are any new ideas out there... include some pictures if possible.
Buck Instagram: C10_ustacould 1963 SWB Fleet Side 528 Desert Beige Milly 1967 SWB Step Side 506 Medium Blue The Old Girl 1968 SWB Fleet Side 503 Light Green Ellie SOLD 1965 SWB Fleet Side 507 Light Blue Prescription Strength SOLD 1971 SWB Fleet Side 521 White Shiro SOLD 1968 SWB Step Side 503 Light Green My Old Farm Truck SOLD |
07-08-2012, 02:29 PM | #6 |
I layed mine flat, right behind the speedo - used a small bungee cord under it and the steering column harness - it's hidden and accessable - I put some dynamat around edges to cushion it from the brake pedal bracket. My cab is crowded a/c vents/hose, radio, vintage air box.
High School Project I ---http://67-72chevytrucks.com/vboard/s...d.php?t=639174 High School Project II ---http://67-72chevytrucks.com/vboard/s...27#post7290427 High School Project III ---http://67-72chevytrucks.com/vboard/s...d.php?t=715832 High School Project IV (Tyler) ---http://67-72chevytrucks.com/vboard/s...d.php?t=780186 Last edited by farmtrucks; 07-08-2012 at 03:09 PM. |
07-08-2012, 02:43 PM | #7 |
Mines mounted under the dash behind the radio area. Its out of sight unless your looking for it.
1969 shortbed c/10 1998 GMC sierra |
07-08-2012, 05:00 PM | #8 |
I could not get mine to reach to under the glove box. So I did this.
no pics after I painted it black and mounted it but it is easy to get to and looks good.
Rex |
07-08-2012, 05:31 PM | #9 |
on the firewall, behind the intake.... hidden, yet easy accessible...
here is a write up on it http://67-72chevytrucks.com/vboard/s...d.php?t=375461 .
Twin Turbo 64 nova project http://67-72chevytrucks.com/vboard/s...d.php?t=669163 68 camaro LS2/T56 vs. 06 GTO build http://67-72chevytrucks.com/vboard/s...d.php?t=516310 project incredible hulk build http://67-72chevytrucks.com/vboard/s...d.php?t=269754 project big red build http://67-72chevytrucks.com/vboard/s...d.php?t=342165 project "blue ray" build http://67-72chevytrucks.com/vboard/s...d.php?t=405465 |
07-08-2012, 05:59 PM | #10 |
That is sweet, but the engine is in my truck so I can't get to that area to drill holes or weld the tabs on. I do like the idea of using the factory box. I think I am going to mount mine to the backside of the radiator support on the drivers side.
07-09-2012, 11:16 PM | #11 |
Still Just Havin Some Fun!
Buck, I have one of the factory mounts... It was in my toolbox and I forgot about it.
a green one with some stuff done to it.... |
07-10-2012, 01:55 AM | #12 |
Here's mine
Posted via Mobile Device |
07-10-2012, 11:54 AM | #13 |
nice ^ !
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
07-10-2012, 07:21 PM | #14 |
Mine is inside the ammo box
03-27-2014, 09:17 AM | #15 |
i was thinking a very similar idea....just when i thought i was being original!!!!
Sgt Dennis Heineman USMC Aviation Ordnance I.Y.A.O.Y.A.S 2001-Present 84 K10 2000 trans am ws6 2011 nissan altima 2009 Troy Built with a 42 Inch Deck My LS Swap http://67-72chevytrucks.com/vboard/s...=1#post6559371 |
03-27-2014, 09:33 AM | #16 |
Mounted to the A/C evaporator housing with riv-nuts. It's not a stock ECU and is substantially lighter; I'm not sure you could get away with that on a stock ECU. Will try to get pictures up soon.
Matt Cramer 1972 Chevy C10 - 4.8 swap, long bed, and maybe one dent free body panel somewhere - SOLD 4.8 LS build thread |
03-27-2014, 10:59 AM | #17 |
I mounted mine under the dash on the drivers side. I built a bracket and welded it to the brake support.
1972 GMC Jimmy 4x4 LS Swap 1985 Chevy K20 1994 GMC Yukon 2021 GMC 2500HD Duramax AT4 My "It's a Jimmy Thing" Build http://67-72chevytrucks.com/vboard/s...d.php?t=583528 Budget Build 1985 K20 http://67-72chevytrucks.com/vboard/s...d.php?t=801565 |
02-03-2016, 04:27 PM | #18 |
C10 Collector
I figured this was worth bumping up even though its very old. Good pics, great ideas. Any others out there?
Im thinking of mounting my pcm and TAC module on the frame rail.
///Ryan 1972 Chevy C-10-Bagged, Blown LT1, 700r4, Suicide Doors 1967 GMC- SC & Cam'd 4.8, built 4l80, 3200 stall, posi, 4.10 1967 Chevy LWB- 454 and patina 1971 Blazer - Rusty 1968 Crewcab project |
02-03-2016, 04:42 PM | #19 |
Boosted Member
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq 1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift 1964 Buick Skylark Twin TURBO 383 LS pro-touring project 2014 VW Passat TDI - Daily Driver Turbo diesel 2015 Sierra Denali HD Duramax Turbo diesel 2023 Ford Explorer ST - Twin Turbskis 2023 Ford F150 RCSB - Whipple Supercharged 2017 Polaris RZR Turbo 2014 Nor-Tech Center Console - Twin Supercharged Outboards TURBO ALL THE THINGS!! |
02-03-2016, 06:54 PM | #20 |
Old member
Mine is in the glove box. I mounted the little LED in the under dash hole in the truck for the check engine light. It was already there. At some point I'll move it to the dash it self.
02-03-2016, 07:00 PM | #21 |
C10 Collector
I have an older vintage air setup and it takes all the room under most of the dash. Gonna have to look at it a little harder.
02-03-2016, 07:25 PM | #22 |
Put Vintage Air in 70 C10 which did away with blower motor. Mounted to firewall where motor was.
02-03-2016, 08:03 PM | #23 |
Keepin an eye out
Mines mounted to the driver side inner fender on a fabbed bracket but this tread now has me thinking about relocating it/
1970 Chevy C10 SWB 5.3 1996 Toyota Tacoma SR5 4x4 2007 Vespa GTS 250 Scooter ZIP 91351 |
02-03-2016, 08:15 PM | #24 |
Mine is also I the glove box.
02-04-2016, 10:54 AM | #25 |
I have my e38 ,for a gen 4 motor ,mounted on the brace between the front drivers fender and core suport , looks as if its made for it , relays below mounted to inter fender
68 Long Fleet , ly6 , turbo 350 , 3-5 drop , original paint , front discs 67 Small window , 7 foot bed , tweaked 6.0 LSX 2004R Medium Olive 58 Apache fleet , 235 , offy intake , dual exhaust , 4 on the floor , red/white 69 Long Fleet , Custom , 6.0, 4l60 , AC , Medium Olive |
