Old 05-06-2010, 08:11 PM   #1
74 C-30
Dually Pride
74 C-30's Avatar
driveline vibe ??
I got a mean driveline vibe since I replaced my carrier bearing. also should my rear driveshaft be balanced?
If I have to explain, you wouldn't understand.
'74 Chevy C-30 350/4 speed/dually
'94 Ford Ranger
74 C-30 is offline   Reply With Quote
Old 05-06-2010, 10:03 PM   #2
STOCKISH
Formerly- 1972SuperCheyenne
STOCKISH's Avatar
Re: driveline vibe ??
Did you mark the front and rear halves of the driveshafts to keep them aligned properly? If you didnt put the two halves back together the same way you took them apart you can get a vibration because the 2 piece driveshafts are balanced as an assembly, not as seperate halves.
--Josh
Old 05-13-2010, 10:19 AM   #3
74 C-30
Dually Pride
74 C-30's Avatar
sorry about the long wait...hate not having internet...
I thought the 2 pieces only went back together 1 way, theres one larger spline.
it doesn't help that the yoke on the rear was welding on and never balanced, but before i replaced the carrier bearing the vibration wasn't this bad
'94 Ford Ranger
Old 05-13-2010, 02:50 PM   #4
Matt Man
Matt Man's Avatar
you need to re balance the drive shaft.
86 c30 crew cab dually 454/400 4/6 drop SOLD 1-8-11
1981 chevy K10 short Bed Scottsdale SOLD 10-26-2020
67 GMC Stepside Straight six/3 on the tree "The Peach"
2020 Silverado Double Cab LT Z71 5.3 8 speed Daily Driver
K10 build http://67-72chevytrucks.com/vboard/s...d.php?t=671934
The Peach build http://67-72chevytrucks.com/vboard/s...d.php?t=733903
Matt Man is offline   Reply With Quote
