Old 05-07-2010, 11:52 AM   #1
basenjib123
Would a C-20 be good for towing and as a DD?
Which truck is best as a daily driver and will be able to tow a 3500 LB boat/trailer. Is there anything stock in the 60-65 era that will do this towing? or will I need something that has been modified? I was thinking a C20. I figure the brakes are a definite upgrade to disc but how about other aspects? Please feel free to cover things that I have not mentioned as I am a newbie big time. Thanks, Joe.
Last edited by 63 & 64 Bowties; 05-09-2010 at 10:01 AM. Reason: WTB by non-subscribing member
basenjib123 is offline   Reply With Quote
Old 05-07-2010, 01:09 PM   #2
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
Re: Searching for a truck that will..
A c20 would be perfect for that. If it were me, look for one and update it with power brakes and front disc brakes from a 73-87 c20 and it should be ready to go. You do know that when you are driving a 40+ year old vehicle you will be subject to issues, right?
Where are you looking?
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 05-07-2010, 01:23 PM   #3
65Gregg
65Gregg's Avatar
I tow a 225 Masercraft Maristar with my 65. I have converted to 5 lug front and rear w/373 gear and 700R4. My current 350 is a mild build w/Vortec heads, HEI, Performer intake and 600 cfm carb. I don't have any complaints other than if the ramp is steep AND wet it is a little dicey. Good luck
65Gregg
Blue long bed
White TBSS
61 Impala
“The two most important days in your life are the day you are born and the day you find out why.” Mark Twain
65Gregg is offline   Reply With Quote
Old 05-07-2010, 04:18 PM   #4
basenjib123
Yes, I realize there will be issue with an old truck. I am a bit concerned about a C20 because they do not seem to be that common...atleast where I look, Ebay, Hemmings, Craigslist etc. Thanks for the feedback and please keep it coming.
Old 05-07-2010, 04:23 PM   #5
Captainfab
60-66 Nut
If you're looking at towing only 3500# then a C10 will do that no problem. I would go with a V8 and either a manual 4 speed, or a TH350,400 or 700R4. I wouldn't go with a powerglide.
Old 05-08-2010, 01:40 PM   #6
Russ65C10
Russ65C10's Avatar
I tow a 18 ft searay that weight right around that with my C10 that has a 283, 700R4 and 3.73 rear end does just fine. Oh yes I do have disc on the front it would be a little dicey in the hills if I didn't ;-)
Russ65C10 is offline   Reply With Quote
Old 05-08-2010, 02:38 PM   #7
basenjib123
Thanks for the replies...about the brakes, do you guys have brakes on the trailer? I do not.
Old 05-08-2010, 02:58 PM   #8
setandreel
setandreel's Avatar
well I remember my uncle's 65 in 65 - the 70s he hauled his Willy's gasser to the tracks and his tractors during the planting season. And now I use it to haul my 21 ft champion bass boat and my f**d 8N. 230 and 3 on the tree. same set up as from factory on the breaks.
setandreel is offline   Reply With Quote
Old 05-08-2010, 06:45 PM   #9
Russ65C10
Russ65C10's Avatar
I did install trailer brakes on mine but I did mostly because I haul it up and down a big hill.
I would always recommend trailer brakes on something the size you're talking about towing regardless of what I was towing it with, its just worth the cost.
I grew up in the mountains and all it took was pushing the truck a little or hauling a load and the drums would over heat and fade, so I am big believer of putting disc brakes on the fronts of our trucks no matter what. Some people will argue that properly set up drums work just fine but I am not one of them.
Old 05-08-2010, 11:37 PM   #10
basenjib123
Yeah, I just hate trailer brakes especially in salt water that I fish in alot. I have tried the best disc systems I know of (Kodiak, etc.) and they all rust out within a few seasons. I think you are correct though it does help the truck out alot when stopping the rig.
Old 05-09-2010, 04:02 PM   #11
monolith
Zero Albedo
monolith's Avatar
Re: Would a C-20 be good for towing and as a DD?
I can't really offer any input on towing- but I've been daily driving my c1500 for most of the past year and having a great time with it. My commute is 60 miles each way, into LA and back from Ontario.
I plan on putting a class 3 hitch on it as soon as I'm done lowering the rear a bit, I want to pull a car hauler with it occasionally.
Baz
"Deserve's got nothin' to do with it."
66 GMC 1500 wideside longbed 250 4spd "Project Rekker"http://67-72chevytrucks.com/vboard/s...d.php?t=467467
65 GMC 1Ton Panelhttp://67-72chevytrucks.com/vboard/s...32#post4794432
65 Chevy Panel (former U.S.Navy truck)
64 Chevy Suburban Carryall 4x4http://67-72chevytrucks.com/vboard/s...d.php?t=358348
64 GMC 1000 wideside longbed 305 4spdhttp://67-72chevytrucks.com/vboard/s....php?p=3600890(Rip- parts truck now)
68 Dodge Charger
monolith is offline   Reply With Quote
