![]() Join Date: Nov 2008
Hi guys..I just ordered a new turn signal switch for my 68 c10....its non tilt and i took the old one out (was broke and the arm was hanging loose).
Well i got the new switch today and the new arm..and I can see where the arm goes on the switch but there is only a non threaded hole..It didnt come with a screw and there was no screw on the old one (seemed to be epoxied in ..probably why it snapped)...I looked in my manual and cant tell what is suppose to be there..a roll pin..screw..etc....If anyone has a clear pic i'd appreciate it..or a part number or where i can order whatever holds the arm on..thanks.. kevin |
![]() Join Date: Aug 2001
Re: Turn Signal Lever (How does it Attach?)
IT'S JUST HELD IN PLACE WITH A PHILIPS HEAD SCREW. THAT LITTLE CHINESE FELLER THAT MADE IT PROBABLY FORGOT TO THREAD THE HOLE. A SELF TAPPING SCREW WILL PROBABLY GET YOU SIGNALLING YOUR TURNS AGAIN.
junkyardjohn 69 1 TON TOW TRUCK // 84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. ![]() LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS) DON'T RENT U-HAUL ALWAYS TELL THE TRUTH IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST Last edited by junkyardjohn; 05-07-2010 at 03:28 PM. |
#3 | |
Shake and Bake!
![]() Join Date: Feb 2010
"All tyranny needs to gain a foothold is for people of good conscience to remain silent." Thomas Jefferson "You are remembered for the rules you break." General Douglas MacArthur "Support Our Troops And The NRA" |
its all about the +6 inches
it has to be very short.
the stock one is a fine thread phillips head, only 1/8th or so long if memory serves |
