05-07-2010, 07:59 PM | #1 |
THE DAMN YANKEE
For sale 72 5 lug suspension
Stock spindles pr 50.00
calipers 25.00 pr rotors 1.25" used but good condition 25.00 power steering box w pump n hoses 50.00 a arms bare 25.00 pair springs stock used 25.00 pair trailing arms used 25.00 pair 5 lug rear good 50.00 complete come get it all for 200.00 5 lug suspension with powersteering set up for 200.00 ! This stuff is too heavy to ship. |
05-07-2010, 09:35 PM | #2 | |
VA72C10
Re: For sale 72 5 lug suspension
Looking for a 67-72 swb or blazer project in or around VA. |
05-21-2010, 11:31 AM | #3 |
THE DAMN YANKEE
no truck to get out your way. ttt
05-21-2010, 01:59 PM | #4 |
VA72C10
Didn't hurt to ask bump for you.
05-23-2010, 03:29 PM | #5 |
hey,
what gears are in the rear end? I'm in PG Co. Where are you? DTT
broke d!@k dog Garage 1969 C20 - Project: "Big Sexy" [http://67-72chevytrucks.com/vboard/s...d.php?t=454894] 2003 'Burban - [Big Pop's daily driver] 1969 350/350 Stingray - [as soon as the economy turns...] 1939 Chevy Roadster Pick Up - Project: "Pre-School" (searching now) |
05-23-2010, 06:46 PM | #6 |
How good is the trailing arms any rot? And is the rear 12 bolt or 10.If arms are good PUT ME IN LINE.AND COULD YOU MEASURE BETWEEN THE REAR BACKING PLATES WHERE THE HOUSING BOLTS TO IT . THATS THE MEASUREMENT I NEED.
05-23-2010, 08:27 PM | #7 |
THE DAMN YANKEE
bddcustoms, i 'm not sure on the gear without cracking it open and counting teeth. i believe it to be a 3.08 gear. the model ce10704 it came with a 350eng/350 trans codes ls9/m49.its a good highway gear. i live in stm.county near NAS Patuxent River Naval Base. it's about a good hour from you. lmk if your interested.i have lots of other parts not yet listed also. phipp
05-23-2010, 08:39 PM | #8 |
THE DAMN YANKEE
as for the trailing arms they're rusty but stll useable. i made my own ladderbars thats why i took them off. as for the rear dimensions is't 58 1/2"wide from flange to flange. thats where the brake backing plate bolts to. i took this good rear out of my 72 C-10 stepside.
05-23-2010, 10:33 PM | #9 |
I am interested. If you can read the axle code (you probably know, but in case you don't on the bottom front of the diff housing, driver or passenger side). should be three alphabet beginning with an "R".
let me know. David
05-24-2010, 07:25 PM | #10 |
Is it a 10 bolt or 12 bolt rear. How far are you from the del. Mem.bri.
05-24-2010, 11:17 PM | #11 |
THE DAMN YANKEE
BDD CUSTOMS the code is NOT located on the housing its on the axel tube @ 2 o'clock drivers side. here it goes RHA WO59 2 I'M 99% sure it's NON-Posi pretty sure it's 3.08 gear. i'm 3 hrs south of the del mem bridge . i drive speed limit.. ok 10 over max! zip 20628
05-27-2010, 04:02 PM | #12 |
THE DAMN YANKEE
it's a 12 bolt rear also. lmk phipp
06-20-2010, 08:17 PM | #13 |
Phipp,
Do you have any stepside components, swb? I'm looking for bedsides and fenders, mainly. thanks.
06-20-2010, 09:06 PM | #14 |
WOW that's a deal
