Old 02-11-2003, 12:12 PM   #1
Yukon Jack
Post Whore
Yukon Jack's Avatar
My dumb engine temp sender ? for the day
The 1989 454 I am installing in the 69 of course has the wrong style temp sending unit - I went to a GM parts at a local dealer yesterday to try to get a sending unit for the 69 and he says that part is discontinued. All he could get was a sending unit for like a 73-78 engine. He was going to have to special order it - go figure!
My guess is the size and thread of the temp sending unit hasn't changed regardless of wheather it's a big or small block or a 69 block or a mid 70's block - BUT does any one know for sure?
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 02-11-2003, 02:14 PM   #2
Tynee
I miss this truck.
Tynee's Avatar
I would definitely find out before you order ( if you haven't already). I ordered a seat belt for the wife's car thinking that if I found one at a junkyard, I'd just return the one I ordered. Didn't think about the restocking fee they wanted to charge. I wound up just putting the new one in instead of the J.Y. one. They wanted that much to return the new one.
'07 GMC Acadia SLT. Sweet ride.
'08 Crew Cab Z-71 short bed. Really like this truck A LOT.
Tynee is offline   Reply With Quote
Old 02-11-2003, 02:37 PM   #3
Blazer1970
Blazer1970's Avatar
I am not sure about BB heads, but on small blocks the old heads had 1/2 NPT taps for the senders, and on the new stuff (Vortec heads for sure), it is 3/8 NPT. I think they changed to 3/8 long before the Vortec engines, but I am not sure what year.
Blazer1970 is offline   Reply With Quote
Old 02-11-2003, 06:58 PM   #4
Fred T
Cantankerous Geezer
Fred T's Avatar
Yukon, if you don't get your answer here try a local mom & pop parts store. they can tell you.
Fred
There is no such thing as too much cam...just not enough engine.
Fred T is offline   Reply With Quote
Old 02-11-2003, 07:02 PM   #5
Earl Junior
Cadillac power
Earl Junior's Avatar
That is really odd.
I bought a 1968 Chev 327 sending unit not three days ago. It threaded right into my 1974 Cadillac 500.
I bought it from Schucks no less. I'd check somewhere else for the part.
Just for the record, if I'm down to my last potato, I'm not sharing it with a guy who wants to kill me so he can get a better supply of virgins in paradise. That lesson is a little thing I call Economics 101, infidel style.
--Scott Adams author of Dilbert
Earl Junior is offline   Reply With Quote
Old 02-11-2003, 08:00 PM   #6
68 Stepside
huh?
68 Stepside's Avatar
Yeah, any discount place should have a temp sender for it. But as stated, I'd check your thread size. If the hole is smaller, there's a temp sender that's in some Volvo cars that will work perfect, someone will know what part number it is.
T
Someday when I'm lonely,
Wishing you weren't so far away,
Then I will remember
Things we said today.
RIP El Jay
68 Stepside is offline   Reply With Quote
Old 02-11-2003, 10:12 PM   #7
Mike C
Mike C's Avatar
Just about any of the board vendors should be able to hook you up with the right sender. You may have to put it in the intake instead of the head. If you can get the specs on the sender (service manual should have the range to test it) you might be able to use the newer one or an aftermarket gauge one.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
