Old 05-07-2010, 10:22 PM   #1
t&tkennels
t&tkennels's Avatar
Thinking about a 4 speed manual
im thinking of replacing my th350 with a 4 speed . i know i will need the clutch pedal assembly & fly wheel . what else should i know before attempting this swap.
t&tkennels is offline   Reply With Quote
Old 05-07-2010, 10:30 PM   #2
Rob H.
Rob H.'s Avatar
Re: Thinking about a 4 speed manual
I'm planning on doing the same swap on my 67, so I'm interested in this also. I'm guessing the crossmember and drive shaft from a 4 speed truck as well?
Rob
72 C/10 (under reconstruction)(destruction ? LOL)
48 Willys CJ2A
1952 Super "A" Farmall (Grandfather's)
Rob H. is offline   Reply With Quote
Old 05-07-2010, 10:51 PM   #3
lpaine
lpaine's Avatar
I'm in the process of doing this myself, (my 69 was an auto,but I found a 3 speed saginaw floor shift for it) You'll need the z-bar and brackets,clutch rods and springs and clutch pedal, and one of the brackets need to bolt to the engine block on the drivers side, so the block has to have the threaded holes in it, and the frame needs to have the bracket that the other end of the z-bar ball stud fits into. Hope this helps, sorry no pics, let us know how it turns out.
1969 G.M.C 3/4 Ton 920 (Canadian Version) 307 3 speed, currently apart
1998 Chevy 1/2 ton ex cab V-6 5 speed
1967 Chevy SWB - project truck; not started just yet
lpaine is offline   Reply With Quote
Old 05-07-2010, 11:59 PM   #4
proud71owner
proud71owner's Avatar
i changed my 71 from a 3 on a tree to a four on the floor and i really enjoy it! i installed a hurst competion plus with a saginaw 4 speed transmission. definetly go with the change.
proud71owner is offline   Reply With Quote
Old 05-08-2010, 12:14 AM   #5
You can use the auto cross member with a car 4spd.I`m installing a Muncie M22 and it has the rear mount that sits right where the TH350/400s mount.You will need all the clutch linkage from a V8 truck.I am using an aluminum car bellhousing since no intermediate mount is needed.
Old 05-08-2010, 12:14 AM   #6
beebster
beebster's Avatar
Location: Aurora,Il ..born,raised and still live in the same house
i had a 72 with a 4 on the floor and loved it!
now i'm just looking forward to an overdrive 700r in my 71 longhorn (putting a manual 4 speed is always in the back of my mind, ha ha)
beebster is offline   Reply With Quote
Old 05-08-2010, 12:45 AM   #7
proud71owner
haha the ball joint in the z bar broke on my truck today! where do you suppose i could get another one?
1971 Chevrolet C/10 ShortBed
1978 Chevrolet K/5 Blazer
1986 Chevrolet Silverado ShortBed
Old 05-08-2010, 02:39 AM   #8
heeroyue2002
fat old dude
heeroyue2002's Avatar
my 4 speed had the starter bolted to it.
heeroyue2002 is offline   Reply With Quote
Old 05-08-2010, 08:24 AM   #9
They are available still.If not from GM I know LMC has them.
Old 05-08-2010, 09:12 AM   #10
CSGAS
optomistic ah-so
CSGAS's Avatar
If getting the whole Z-bar works seems expensive or daunting to you, there are aftermarket hydraulic throwout bearings that just involve a line running into the bellhousing opening for the unused linkage, and a racing style clutch pedal and clutch cylinder added to the firewall. Speedway Motors has the parts.
This is just an option, some people like it some don't and some want a specific look or theme for the vehicle.
Rubbing is Racin'
Ribbing is Bench Racin'
1970 C-10 lwb Fleetside. Originally 350 2-bbl 3-on-the-tree, m/b, m/w, m/s no a/c. Currently running on a '76 Camaro 305.
CSGAS is offline   Reply With Quote
Old 05-08-2010, 09:23 AM   #11
prostreetC-10
My Carbon Footprint
prostreetC-10's Avatar
Everthing should fall into place except that bell crank (Z bar). Was yours ever a 4 speed? The Z bar might be left behind. What was most tough for me was the relocation of it. My truck had a 6 cyl and I had to take a torch and very carefully cut the rivots out since they were in fact rivots. Had to relocte it farther back but she's like butter now. Like Special K....I went with that Muncie M-22.
prostreetC-10 is offline   Reply With Quote
Old 05-08-2010, 11:22 PM   #12
jdstx
jdstx's Avatar
The most fun I ever had was in a 69 El Camino with a 327 and a four speed. Well, maybe not the most fun, but I remember it well.
jdstx is offline   Reply With Quote
