Old 05-07-2010, 10:25 PM   #1
1980c-10 mybaby
1980c-10 mybaby's Avatar
How did you guys do your control arm bushings?
So i bought the whole energy suspension bushing kit for my truck and im wondering how you guys did your lower control arms i work at a toyota dealership and our push cant handle the lower control arm bushings the uppers it will handle no problem...... did you guys do them your self or did you take them somewhere to get done..... my father recommended a truck shop might be able to do them...... any help would be nice
1980c-10 mybaby is offline   Reply With Quote
Old 05-08-2010, 01:46 AM   #2
454HO
Re: How did you guys do your control arm bushings?
I use a propane torch to heat the outer metal shell of the bushing. There is no reason to catch the rubber on fire unless you just enjoy the smell of burning rubber. Continue heating until you see the rubber start to swell and melt a bit. What you are trying to accomplish is breaking the bond of the rubber to the metal sleeve. Once the bond is broken, the rubber bushing will pop out with a push from a piece of pipe or a stick of wood.
Some bushing require you use the original sleeve. Other bushing come with a new sleeve, so you have to remove the originals. What I do to remove the sleeve is cut them lengthwise from the inside. Make sure you do not cut into the control arm though. Then use a hammer and drift to crush the sleeve inward at the cut line. They usually come right out.
- Greg
454HO is offline   Reply With Quote
Old 05-08-2010, 02:26 AM   #3
harnalien
TruckincrazY
harnalien's Avatar
I took my uppers and lowers off myself then took them to a shop. I had my ball joints done at the same time. Cost me a hundred bucks, but I don't have any air tools. Air tools would be handy in getting the old bushings out as well as the ball joints. It was tough enough getting the lowers off with hand tools!
harnalien is offline   Reply With Quote
Old 05-08-2010, 06:34 AM   #4
baclay9
Where did you get your kit from?
baclay9 is offline   Reply With Quote
Old 05-08-2010, 05:34 PM   #5
1980c-10 mybaby
i honestly just searched for the energy suspension web site in google and got a part number and ordered from them summit has the same kit for a little bit cheaper if i remember right....
Here is there website.... http://www.energysuspension.com/
you will have to click on the little book on the left side that shows application search.... scroll down get the part number and copy and paste that back into the search bar in google and it will take you straight to the page to buy the item from on the website...... easiest way to do it..... sounds complicated i can tell ya its not
