"THE GREEN GOBLIN"
I tried to drive my truck today made it as far as two blocks to the Gas station fueled up & it was hard to start then it stalled at the light right in front of the gas station. I started looking it over thought it was the Timming so I checked the dizzy. then checked all vacum lines. everything was good. I got it started after trying for while then it stalled again finally made it home where it died again as I pulled up in front of the garage.So I desided to check the carb thats when I noticed it was flooding. I know this is not normal Or is it? It is pouring gas as soon as I turn the key on fuel pump on engine off not from the jets but from the round things in the Carb I never noticed it before but its happening now it never did this. My carb is a 750 cfm, 4-Barrel, Dual Inlet,Proform Race Series Mechanical Secondary Carburetor. I am just wondering if something inside it broke or maybe I messed something up when I changed the intake manafold gasket last week and took the Carb off to clean the tarnish it had on it I used Brake parts cleaner and Carb cleaner to clean it up.
I attached a video to show what I am talking about just click on the photo below the fuel starts to pour out as soon as I turn the key to the on position, in the video it shows it start to pour after I reinstalled the fuel pump fuse. Please if any one can tell me what I need to do to fix this problem.Thanks again in advance for everyones help..
![]() "THE GREEN GOBLIN" 1972 Cheyenne 10 Short Fleet Side Front 2.5inch Spindles with 2inch Springs Rear 4inch drop Springs. 454BBC TH400,Posi 1971 Cheyenne 10 Long Fleet Side 454BBC TH350,Posi ![]() Drive it like you stole it! ![]() Petey-pablo@sbcglobal.net |
Re: Carburetor Flooding My Carb thinks GAS is free is there something wrong with my C
Sinking floats? Causing flooding?
Nothing easy is worth it. |
electric fuel pump without regulator and gauge its a common problem// should b set at no more than 5psi// if you have the option of running the good old reliable mechanical fuel pump that would b the cheapest fix tho
71c-10 350/2004r/4:11 lowered3/4 longbed/dead by hurricane MEANING OF DEATH::::: SOMEBODY ELSE GETS YOUR STUFF DONT BELIEVE EVERYTHING YOU THINK TAKE MY ADVISE;I DON'T USE IT ANYWAY Last edited by cdowns; 05-08-2010 at 06:01 AM. |
Looks wrong to me. You should have no more than 5-7 psi of fuel to the carb or it will overpower the needle and seat and flood the bowls and cause fuel to leak out like you have. Either you have no pressure regulator, pressure regulator is defective or the needle and seat is stuck open. Brake cleaner and carb cleaner is really not supposed to touch anything rubber, says so right on the can, might dissolve rubber parts. Needle and seat has rubber in it. You don't need an electric fuel pump for most street carb installations. Mechanical is best, IMO.
Junior Member
![]() Join Date: Mar 2005
You just have something stuck between the needle & seat . If you never had this problem before.
72 cheyenne super BB402 TH400 Air Tack Tilt Posi P/S P/B AM/FM 12.96 @ 101.82 mph 60ft 1.82 12.39 @111.33 With a 180 shot nos 69 Camaro RS http://s94.photobucket.com/albums/l117/fdelcoglin/ email fdelcoglin@hotmail.com |
Shake and Bake!
![]() Join Date: Feb 2010
Like said above I would check your needle/seat and also check your fuel pressure and regulate it. Something else to be sure to do is change your oil, all that fuel that was pouring out in your vid, and any other time you do that without the truck running has to go somewhere.
It is leaking down into your cylinders and then past the rings into your crankcase and is diluting your oil.
"All tyranny needs to gain a foothold is for people of good conscience to remain silent." Thomas Jefferson "You are remembered for the rules you break." General Douglas MacArthur "Support Our Troops And The NRA" |
I agree. Change the oil and filter for sure. That gasoline has essentially washed the oil from your cylinder walls. Very bad. Don't keep doing that. You don't want those rings running dry against the cylinder walls. Good luck.
"THE GREEN GOBLIN"
Ok I have been running the truck with this set up and it was running good before. I am running a HOLLEY "Blue" Electric Fuel Pump With Regulator set at 7psi the fuel problem just started yesterday. So do I have to open up the Carburetor take it apart to check why the needle and seat is stuck open? Does any one have a picture of what it looks like inside a carb so I know exactly what I am going to Examinate.. Thanks
![]() "THE GREEN GOBLIN" 1972 Cheyenne 10 Short Fleet Side Front 2.5inch Spindles with 2inch Springs Rear 4inch drop Springs. 454BBC TH400,Posi 1971 Cheyenne 10 Long Fleet Side 454BBC TH350,Posi ![]() Drive it like you stole it! ![]() Petey-pablo@sbcglobal.net Last edited by petey-pablo; 05-08-2010 at 01:13 PM. |
Glad I converted over to TPI..
You could try taping the fuel bowl with a hammer handle to get the float unstuck this has worked for me many times after storing for the winter.
"THE GREEN GOBLIN"
Ok I took the carb apart and I did not notice anything that was sticking the float wasn't stuck and moves freely. Could it be this little check valve that is not working ? Is there a way of testing this little valve I tried blowing in it from both sides but It doesn't seem to let the air I blow into it pass through even if I press the little spring thing on it.
"THE GREEN GOBLIN"
I did try tapping it but it remained the same.
#13 |
"THE GREEN GOBLIN"
I was reading that One good backfire can destroy a carburetor's power valve maybe mine needs to be replaced as I did have a backfire not too long ago when my timming was off.
#14 |
You most likely have a piece of dirt in a needle & seat. See witch side is flooding, primary or secondary. Remove the corresponding needle & seat. These are easy to do on a Holley. Remove the slotted screw on top the fuel bowl & screw the N&S out using the hex nut. Save the gaskets. Blow out the N&S, put a little oil on the O ring & screw it back in to about the same level as it was. Then put the slotted screw back in. To adjust the float level remove the screw in the side of the fuel bowl & adjust the fuel level. To adjust it loosen the screw & turn the nut CCW to raise the level & CW to lower it. The fuel should be at the bottom of the hole on the side of the bowl. The power valve can cause flooding but not running over like you describe.
#15 |
Redefining LowBudget
I agree %100...^^^^^^^^^^^^^^^now that it stopped raining I'm going to rebuild mine...
1970 C10 CST fleetside 472 ....big dreams little cash... SunShine Syndicate.. ![]() Mikes Sandwich Fair Run OCT 8th 2011
#16 | |
"THE GREEN GOBLIN"
#17 |
"THE GREEN GOBLIN"
Ok so I went out took it apart and cleaned everything hooked it back up and let it fill with fuel it was looking good No running over. BUT theres Always a but the fuel regulator is tripping I think it is going bad. It goes past 7psi the setting I had set it to. it keeps climbing. Is my fuel regulator no good ? It wasn't doing this before at lease I never noticed it. It was always on the 7psi.
#18 |
"THE GREEN GOBLIN"
Im going out to buy a new fuel regulator hope this solves my problem. I will let you guys know if this works.
![]() "THE GREEN GOBLIN" 1972 Cheyenne 10 Short Fleet Side Front 2.5inch Spindles with 2inch Springs Rear 4inch drop Springs. 454BBC TH400,Posi 1971 Cheyenne 10 Long Fleet Side 454BBC TH350,Posi ![]() Drive it like you stole it! ![]() Petey-pablo@sbcglobal.net Last edited by petey-pablo; 05-08-2010 at 07:51 PM. |
#19 |
"THE GREEN GOBLIN"
I've been at this since 9am this morning I give up, Im ready to SELL THE TRUCK as is ANY OFFERS... The running over of fuel in the carb has stopped maybe its fixed who knows but it isn't pouring out anymore. Now I thought the fuel regulator was bad due to the gauge psi going over the set 7psi. Now thirty dollars latter New fuel regulator its doing the same maxing out at about 12Psi and fluctuating and it doesn't let me set it any lower it moves up but not down,maybe the gauge is bad ? But the pouring of the fuel has stopped Now
![]() "THE GREEN GOBLIN" 1972 Cheyenne 10 Short Fleet Side Front 2.5inch Spindles with 2inch Springs Rear 4inch drop Springs. 454BBC TH400,Posi 1971 Cheyenne 10 Long Fleet Side 454BBC TH350,Posi ![]() Drive it like you stole it! ![]() Petey-pablo@sbcglobal.net Last edited by petey-pablo; 05-08-2010 at 10:17 PM. |
#20 |
Replace the gauge. I had that exact same issue with climbing pressure on my boat just last week. It was even the same Summit gauge. Sounds like you have some trash in the line. I would replace the fuel filter as well. Trash could cause both the issues you have been experiencing.
72 Cheyenne Super 1/2 LWB White/Dark Yellow 07 Avalanche 2LT 74 Sleek Craft Rebel Jet Boat W/Pontiac 400 Last edited by OhOneWS6; 05-09-2010 at 10:17 AM. |
#21 |
I would try the standard mechanical pump for sure and as a baseline change the carb out to a known good carb then take it from there . that might be what will it do for ya. don't know if someone already posted this if so, sorry. best of luck, Pat
#22 |
"THE GREEN GOBLIN"
Problem solved who knows what it was I took the carburetor completely apart for cleaning again last week and back together again and it fixed the problem. Now I just need to set My Idle Mixture screws because I moved them and don't remember how they were set..
