Can i replace the whole rear with a truck bed
I have a 72 with alot of bad body work in the rear and I found a near perfect truck bed. and I think it would be easier to cut it from behind the door jambs and replace the floors and all in one shoot.
Re: Can i replace the whole rear with a truck bed
Yes, but you will have to take a section out behind the wheel wells and weld it back together and you will also need to cut the front off and weld a Blazer front floor section on.
1969 Chevy Custom Camper 3/4 ton Rust free survivor 1972 Chevy Blazer CST 4x4 Almost Rust free survivor 1972 GMC Jimmy 2wd Undergoing surgery |
If it is a swb it will be much easier, but the cross sills are different on pickup beds than on blazers at the frame mount locations. The sills on a blazer are recessed. I used my orginals and welded them in.
"85" Monte Carlo SS "71" K5 (SOLD) "64" Chevelle 1930 Chevy two door rat |
I wanted to find a short bed but a local guy has a mint long bed for $400 I am thinking or waiting but thats a good price to have a perfect rear clip for my truck.
New Member
Also, long bed wheel well arches are different. Short Bed and Blazer are the same.
SKINNY TIRES RULE!
They are? I never knew this... Good info
bouncytruck 1972 K5 The Hauler 1994 K1500 Suburban The Daily2010 Kia Soul Wife's Ride2014 Fiat 500L |
So Many Ideas, So Little Money
they only sell one replacement wheel arch though. not a swb/blazer one and a lwb one?
we sure thats true?
72 Blazer 3/4 ton running gear 4.10s NP205/TH350 350 4in lift half doors 71 C10 with 454 99 S-10 5.1L SBC 700R4 09 Malibu ![]() Marshalltown, Iowa |
Its true but no big deal. Not a show truck. Just an old junk 4x4 that is going to redone in 2wd with rack and pinion steering, flip kit in the rear and an 02 ls1 with a matching auto trans. I put a pic of the rack set up I will use.
The difference is in the edge in front of the tire. Dont have the pics that were sent to me but I will try to explain, the area is at the lowest point of the wheel opening in front of the tire, (red circle) blazers and swb sides come to more of a point where as lwb sides have more of a sweep to the front. Also you might want to think twice about using lwb bed, alot of work to make it work. Also the arch that is sold is only slightly larger than the area in black
"85" Monte Carlo SS "71" K5 (SOLD) "64" Chevelle 1930 Chevy two door rat Last edited by Bentblazer; 05-09-2010 at 06:48 PM. |
its going to look pretty cool with that suspension
cucharitas customs |
Junior Member
Does anybody make replacement cross sills for the blazer?
1970 blazer, street/strip project 1963 ford fairlane sports coupe 50,000 original miles |
Not to my knowledge, may have to try and salvage original ones.
