Old 05-08-2010, 08:43 PM   #1
seafoam68
seafoam68's Avatar
where does everything bolt on ?
Need a little help. I pulled a 454 with a/c from an '81 c-30 to use in my hot rod. I have now replaced the 454 in the c-30 with a 350. The 350 had no a/c. I am trying to figure how to bolt on the compressor. On the 454, the compressor was on pass side. The 350 has alternator on pass side. Does anyone have pics of stock 350 and 454 with a/c so I can compare ? I am thinking I can mount compressor on driver side, if the p/s pump isn't in the way, and just get longer a/c hoses ? thanks guys....
seafoam68 is offline   Reply With Quote
Old 05-08-2010, 09:04 PM   #2
cableguy0
Re: where does everything bolt on ?
The brackets do not interchange between a sb and bb. You will need to get the ac brackets for a sbc. including crank and water pump pullies.The easiest to find brackets will all have the alternator on the passenger side. The last vehicles to use a driver side alternator factory were the 72 chevy p/u and those brackets arent that easy to come by especially with a/c stuff. your best bet will probably be to go to the junkyard and find a truck with a/c and rob the brackets so you have everything you need.
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member.
cableguy0 is offline   Reply With Quote
