Quick diesels here?
Anyone swapped a Cummins or Duramax in a square body and gone racin'? Whats your recipe and what kind of power are you making?
Re: Quick diesels here?
I race my cummins powered 72 a few times a year. My engine setup, '94 cummins, s300 turbo, bigger injectors, a few injection pump mods. Drive train, nv4500 trans, np205 tcase, dana 60 front, dana 80 rear 3.54 gears, 6'' lift, 35'' tires. Not a race truck but it will get out of its own way. Best time so far 14.2 @ 96 mph. Never had the truck on a dyno but I am guessing around 400 hp.
Sounds like a fun set-up. I've seen some diesel racing on the 'puter and I figured maybe a few from this board have coal burners that they'd race. Some of those rigs are very fast and will dust many built musclecars.
i have a 97 ford 4dr shortbed 4x4, you name it, it has it. it put down 375hp on the dyno with 37s. not bad for a old 7.3 non intercooled that was rated at 215hp at the flywheel.
If I remember correctly, Midevil has a diesel that puts out some impressive numbers. I think I remember him mentioning it a few years ago on a different forum.
1982 Silverado - SBE, cleaned up GM heads, small cam, TH350, 850 Demon, 4.56 gears, and caltracs. Best time so far 11.8@XXXMPH |
Those are some nice numbers for the 7.3. My father has an '00 7.3 with a chip and exhaust and that really woke his up. Care to share your mods?
#7 | |
off the top of my head it has... dominator66 turbo 17* high pressure oil pump for the injectors injectors custom fuel pressure shim custom tony wildman chip modded injector drive modual down pipe with custom 5in dual exhaust built trans by mikes trick shift really long traction bars exhaust brake shaved tailgate lifted on 35s its under going a dana60 swap right now, so i might run 37s again. heres a video and pics... ![]() ![]() |
I don't like fords, but that thing is nice...
http://67-72chevytrucks.com/vboard/s...d.php?t=494388 431 big block times, changed to a 6.0 ls with turbo 1.58- 60' 7.18- 1/8th mile@95.18 11.37- 1/4 @115.81 |
Friend of mine from Emory has an 02 duramax that runs 10's in the 1/4. He also owns a diesel performance shop. Here is his website and you can see videos.. it's a very nice/fast truck... http://www.dieselhotrods.com/
Shawn
Shawn 85 SWB 7.39 @ 93 Best so far with 0 tuning Lesson in life: Never fry bacon naked! |
At the body shop.
On Youtube.
" That didnt make it any newer " " Dont antique the equipment " |
[QUOTE=fiddy9apache;3968969]thanks...
off the top of my head it has... dominator66 turbo 17* high pressure oil pump for the injectors injectors custom fuel pressure shim custom tony wildman chip modded injector drive modual down pipe with custom 5in dual exhaust built trans by mikes trick shift really long traction bars exhaust brake shaved tailgate lifted on 35s its under going a dana60 swap right now, so i might run 37s again. heres a video and pics... ![]() ![]() Digg it ![]() |
6>8 Plugless........
![]() Join Date: Sep 2007
I just saw this thread, don't know how I missed it. I have many diesel burning rides. My favorite one has to be my corvette!
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
#13 |
I put a Duramax in my 69 c10. The truck is a blast to drive on the street. By the push of a button I can switch from 450,550,650 and 708HP.
http://www.youtube.com/watch?feature...&v=SCa8-X_wWKs
1969 C10, 2005 LLY Duramax, Wagler Competition built motor, Bullseye Power triple Turbo's, Rossler th400, Neal Chance Racing Converter, Danville Performance tunning. 8.3@168mph 1700+ HP |
