Old 05-08-2010, 10:31 PM   #1
Billhilly
Billhilly's Avatar
Smoothing/Mirroring Firewall ?
Hey Guys,
Working on my firewall and want to plug the 'blower hole' on the firewall and 'mirror' left hand side contour, over to right hand side (kind of like the red line below). Is this panel normally just 'cosmetic', I mean looks good from the front, but has a gap between firewall/cowl area?? Or do you some how weld in a 'bridging' piece to extend the channel where the stock wiring harness runs? (Want it to look like the bottom photo).
Any thoughts on this appreciated.
1972 K2500 Long Box
400/350
Billhilly is offline   Reply With Quote
Old 05-09-2010, 12:43 AM   #2
basemodel67
Factory Strippers Rule!
basemodel67's Avatar
Re: Smoothing/Mirroring Firewall ?
I don't think you need to worry about making it structurally stronger, if that's what you're asking. But I would make it kinda look like the rest of the firewall, with either a cover over the wiring gutter, or have the gutter extend behind the filler piece you add.
"Feast your eyes on a feast of smoke."
67 Chevy Short Fleet
PLAN: LQ9, 4L60, D60
Looking for School Bus Gauges - Help me out!
basemodel67 is offline   Reply With Quote
Old 05-09-2010, 01:02 AM   #3
8mpg
8mpg's Avatar
Not structural...It will be fine without any more bracing behind it. I didnt put anything behind mine.
8mpg is offline   Reply With Quote
Old 05-09-2010, 01:32 AM   #4
Billhilly
Billhilly's Avatar
Thanks Guys,
No, wasn't worried about making it structural. Just wanted it to look 'right' without creating hours of work. Just after some good workable ideas.
1972 K2500 Long Box
400/350
Old 05-09-2010, 09:30 AM   #5
Richard H.
Spanked once
Richard H.'s Avatar
Not a real good angle shot but I mirrored mine and it is not much extra work. I use tracing paper for starting my templates.
HTH ,Richard
The ole 350 budget build.
Richard H. is offline   Reply With Quote
Old 05-09-2010, 10:02 AM   #6
jholley
jholley's Avatar
This is what I ended up doing with mine (when it was still mine). It makes for a much cleaner look if you go ahead and cap the top. It really wasn't all that difficult and turned our pretty well. Here is a link to how it turned out after the new owner painted it.
http://67-72chevytrucks.com/vboard/s...d.php?t=380813
Jim
Garage fillers...
85 Chevy C10 Silverado LWB
07 Nissan Altima
2006 Mini Cooper S
jholley is offline   Reply With Quote
Old 05-10-2010, 03:42 AM   #7
Billhilly
Billhilly's Avatar
Thanks for the pictures. I will fill it in at the same level as the origonal one I think. Plenty of other panel work to do. You guys do some great work!
1972 K2500 Long Box
400/350
Old 05-10-2010, 11:59 PM   #8
hemihead
hemihead's Avatar
Here's a shot of mine all done, same as above but with paint.
1967 SWB C-10, BBC 454, T400, 3.73 posi, 20" Coys
1972 K5 Blazer, SBC 400, 4 spd, 3.73, 6" lift, 35" mud grapplers
2011 Sierra Denali HD, 6.6 L Duramax, RBP 96R rims, leveled and Nitto trail grapplers,
2009 Acura MDX
hemihead is offline   Reply With Quote
