TBI Mods?
I am rebuilding my throttle body with a full BWD kit. I was wondering if there are any simple mods I can do while it's apart.
1990 Suburban TBI 350
____________________________________ |
Re: TBI Mods?
vortec heads, and a vortec carbd intake and a holley 600 lol ok seriously.. a throttle body spacer wil l help with perf a little and while you have it apart, maybe a small rv cam
"I'll keep my guns, money, and freedom. You can keep the "change" |
Re: TBI Mods?
TB Spacer, Injector pod spacer, Make your fuel regulator adjustable would be my advice. Would also go with a high output pump, but dont "have" to...
'90 Suburban |
In the Forgotten far North.
![]() Join Date: Jul 2007
Re: TBI Mods?
Check with this guy.
www.tbichips.com
1987 R3500 CREW CAB DUALLY (BIG RED)Acquired 06/12/2015 1990 chevy suburban V2500 5.7L My cluster Mods-Nov 2007 overhead console Stereo install Round 2 Aug 2009 Heated/turn signal mirror upgrade |
Fun Stuff
![]() Join Date: Jan 2010
Re: TBI Mods?
here is some good info. http://www.cfm-tech.com/GMTBIPerformanceParts.htm I did some research before, but I have forgotten. Most I got from "Google" high performance tbi. Good luck
![]() edit: Also it would be a good idea to make the pressure regulator adjustable, stock it is just alittle to low.http://www.fl-thirdgen.org/tbiafpr.html
Jay 68 C10(project) 88 Honda Accord(DD) 93 Chevy Astro EXT 2wd Last edited by jayman68; 05-09-2010 at 12:15 AM. |
Re: TBI Mods?
the guy from westers garage in canada is the guy you want to talk to. i built a tbi motor for my brothers 90 and im working out the bugs but he is very intellegent.
#7 | |
Ironmonger
![]() Join Date: Dec 2004
Re: TBI Mods?
But then you'd be investing in some hardware and software to recalibrate the ECM. Not sure what the smallblock TBI intake manifolds are like, the pre-'91 big-block TBI intakes are horrible. But then so are the heads, cam, exhaust, etc. |
