Old 02-11-2003, 04:07 PM   #1
chevyhouse
BEER-Vacation in a can...
chevyhouse's Avatar
upper radiator hose
I've got a leak at the upper rad hose right at the radiator, it looks to me like it is actually the radiator neck has come lose from the radiator itself. everything is still to gether, the tube is just loose in its mount. can this be fixed with pipe solder of something or am i in the market for a new one??
thanks, kurt
Kurt
03' Trailblazer
69' C10 "SPSHL-K", 388 stroker/BTO 700R4, 2400 stall, 3.73 posi, lwb, fleetside long box, 3.5"/5" drop, 18" Budnik
2000 Yamaha V-Star 1100 Custom
For Sale-87' V10-4x4, 408/700r4, 4.10's PM for pics
chevyhouse is offline   Reply With Quote
Old 02-11-2003, 04:39 PM   #2
crazy longhorn
Fabricate till you "puke"
Yes, thats fixable. A rad shop can do that job for about $20, or if you have done a little soldering you can give it a try. just be carefull not to get too much heat on the tank/header. I have used 50/50 solder on repairs like that. Good luck....crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
