Old 05-09-2010, 09:36 AM   #1
cloudbrk
Steering Column Length Too Long?
I just picked up my first C10 yesterday and have start looking through it and fixing things. While driving it, it seems like the steering wheel is really really close to me. Is it possible for the steering column to be too long? The reason I ask is because the truck was originally a manual trans (clutch pedal is under the carpet) and obviously has a different steering column because of that. I think that is might not be the right one.
How far from the instrument cluster should the back of the steering wheel be?
cloudbrk is offline   Reply With Quote
Old 05-09-2010, 09:43 AM   #2
Cyclone
Cyclone's Avatar
Re: Steering Column Length Too Long?
My stock 1970 is 10.5", back of wheel to cluster
Cyclone is offline   Reply With Quote
Old 05-09-2010, 09:54 AM   #3
cloudbrk
Thanks Cyclone....Mine is the same. I guess maybe I just need to lose some weight!
Old 05-09-2010, 09:58 AM   #4
71swb4x4
71swb4x4's Avatar
You can move it back. If you have the collapsable steering shaft drill out the platic rivets, and with a little work you can get another couple inches out of it. There is a good thread on this, I will see if I can find it.
Edit: here you go. http://67-72chevytrucks.com/vboard/s...d.php?t=191143
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 05-09-2010, 09:58 AM   #5
Cyclone
Cyclone's Avatar
Shorten it.
Old 05-09-2010, 10:03 AM   #6
hugger6933
Yea, it is a tight fit . I am 6'2 and go over 360lbs and I'm real close to the wheel in my 68. My 70 did'nt seam as bad but it has a bench seat and a smaller wheel. My 68 has the big wheel and buddy buckets that I think sets up a little bit higher. Jim
hugger6933 is offline   Reply With Quote
