Old 05-09-2010, 10:04 AM   #1
turner15
steering column
will an 84 steering column from a burb fit in my 80 3/4 ton? It has a tilt. should be worth the upgrade. Yes?
turner15 is offline   Reply With Quote
Old 05-09-2010, 11:50 AM   #2
81ratrodc10
house of chevy's
81ratrodc10's Avatar
Re: steering column
i dont c why not i have a 83 tilt from a burb in my 81 cant be any diffrent
81ratrodc10 is offline   Reply With Quote
Old 05-09-2010, 11:56 AM   #3
73chevyman
73chevyman's Avatar
Re: steering column
if you can put your stuff on it yes..... 80 and 84 wiring different and they started adding stuff to the turn signal... if you can innergreat your turn signal switch and what ever else then yes
http://67-72chevytrucks.com/vboard/group.php?groupid=37
73 C10 Fleetside
If it ain't a Chevy it's foreign
http://hotridesmag.com/
73chevyman is offline   Reply With Quote
Old 05-09-2010, 12:10 PM   #4
DubDubU
DubDubU's Avatar
Re: steering column
I have an 88 tilt in a 79, no problem
'79' shortbed
DubDubU is offline   Reply With Quote
Old 05-09-2010, 08:03 PM   #5
73chevyman
73chevyman's Avatar
Re: steering column
did you have to put your stuff on it or everything worked fine
73 C10 Fleetside
Old 05-09-2010, 09:00 PM   #6
80stepsideguy
Laid back freak
80stepsideguy's Avatar
Re: steering column
You will need to swap harnesses as the 84 column has the switch for the wipers as 80 were on the dash.Best thing is to look for a 83 n down column ..
thanks
pat
1980 chevy c10 step side restomod,
1970 cougar convertible 1 OF 24 ever built:
2014 Hyundai Tucson limited (daily driver).
80stepsideguy is offline   Reply With Quote
Old 05-10-2010, 12:54 PM   #7
turner15
Re: steering column
I was thinking of just leaving the wiper stuff on the dash and using an adaptor to connect the signals?
Old 05-10-2010, 01:52 PM   #8
80stepsideguy
Laid back freak
Re: steering column
turner,
you can locate a j/y column or a column from ebay n have it rebuilt.Be something to think about..
thanks
pat
p.s. thats what i did i located a 82 gmc high sierra non cruise tilt column for 50.00 n had it rebuilt..
Old 05-10-2010, 04:38 PM   #9
turner15
Re: steering column
Ya but I have the column
from my old burb
