Old 05-09-2010, 11:10 AM   #1
JimmyFloyd
Front Posi Axle. How to tell?
Ok, so I had a guy come buy the center link on my suburban, and he looked at the axle, and said it looked like it had a Posi tag on it. I am interested to know if there is a tag that denotes it as a posi, or if there is another way to tell? If I have to open it up, will it look the same as a rear posi carrier? It's a D44 axle, appears stock, but I know the rear appeared to have a gear change.
1970 Blazer 350/SM465/205 SOLD! | 1998 Z3
JimmyFloyd is offline   Reply With Quote
Old 05-09-2010, 11:53 AM   #2
too much stuff
Roadtrip!
too much stuff's Avatar
Re: Front Posi Axle. How to tell?
More than likely, the tag will tell you the gear ratio. See what the tag says for sure. Maybe you will get lucky and the tag will read "use posi lube only"
67 gmc custom lwb dakota truck. Sold...And bought back
69 swb 4x4 project (in progress)
70 c-10 lwb texas truck
70 4x4/BB/bkts/posi/tach(retired)
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
71 cheyenne 4x4/tach/posi/ plow rig
71 Cheyenne20 BB, buckets, tach, tilt, 4 speed
72 jimmy CST wyoming rig
72 jimmy Colorado rig
72 lifted texas 4x4 3/4 ton burb
65 fury conv. 383/auto
65 chrysler 300 "L" 413 auto
too much stuff is offline   Reply With Quote
Old 05-09-2010, 03:43 PM   #3
kev0519
jack up one side with everything locked in see if there is resistance in turning wheel should be resistance [clutches in posi]
kev0519 is offline   Reply With Quote
Old 05-09-2010, 08:01 PM   #4
LONGHAIR
I don't think they ever did it from the factory....I would pull the cover and have a look. It could use some fresh lube anyway.
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 05-09-2010, 09:43 PM   #5
JimmyFloyd
Ok, got some pictures and the numbers off it. It appears that it might be a Posi
Here are the pictures:
Numbers read: 12 21 69 Dana 18520 A3d45 45-11
Numbers Read: 10 26 67 C 23181x
So, is this a Posi axle?
Old 05-09-2010, 09:45 PM   #6
basemodel67
Factory Strippers Rule!
basemodel67's Avatar
I think front posi was an option... not sure that is factory, though.
"Feast your eyes on a feast of smoke."
67 Chevy Short Fleet
PLAN: LQ9, 4L60, D60
Looking for School Bus Gauges - Help me out!
basemodel67 is offline   Reply With Quote
Old 05-09-2010, 10:15 PM   #7
JimmyFloyd
just trying to figure out if this is a posi or not. no need to know if it is factory cause it wasn't on the SPID
Old 05-10-2010, 09:08 AM   #8
JimmyFloyd
Anyone know on this?
Old 05-10-2010, 09:20 AM   #9
bigsnookmaster
bigsnookmaster's Avatar
Jack up the front without it being locked in. Turn a wheel, if the other wheel turns the same way, it's a posi. If it turns the other way, it isn't. That's the way I always tell. If it is a posi, you can have someone hold one wheel while you turn the other, to see how tight the unit is. I know on my 9" rear, it takes quite a bit of force to get the posi to slip. Good luck
bigsnookmaster is offline   Reply With Quote
Old 05-10-2010, 09:25 AM   #10
JimmyFloyd
I would try that, but it's on a trailer and strapped down and sitting on an incline, so I can't really jack it up. I am hoping someone can tell by the pictures.
Old 05-10-2010, 09:45 AM   #11
JimmyFloyd
Ok, little more research, and it seems like it is a POWR-LOK limited slip for a D44 as seen on this site:
http://www.shopih.com/POWRLOK-D44-p-AR.html
And here too (near the bottom):
http://www.vernco.com/powr-lok/
Time to figure out how to get it out.
Old 05-11-2010, 08:42 AM   #12
RustyParts
RustyParts's Avatar
According to the numbers on the ring gear it's a 4:10 ratio.
1972 GMC Jimmy, 4WD, 454 CI, 350 Turbo, 4" lift, 35" tires
The math teacher said my son "Bubba" could be a mathmatical genius. cause he's got 13 fingers!
RustyParts is offline   Reply With Quote
Old 05-16-2010, 11:21 PM   #13
Rod
It's a posi, power-lok, has a clutch pack and it is rebuildable. Requires the posi-lube additive also.
Senior active founding member.
70 3/4 ton GMC Suburban 4x4 250/4 spd.
71 1/2 ton Suburban Chevy 4x4, 350/350
72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane
2005 FLSTSCI Harley Springer
85 FXSB Harley Lowrider
72 Triumph 650 Bonneville 5spd
"Poor people don't have hobbies" Quote from wife.
Rod is offline   Reply With Quote
Old 05-18-2010, 04:13 PM   #14
D.PASSMORE
One of the First
D.PASSMORE's Avatar
If so, the Old sub was set up for heavy four wheeel'in. DEEEP SNOOWW!!
D.PASSMORE is offline   Reply With Quote
Old 05-18-2010, 04:18 PM   #15
JimmyFloyd
Yeah, it was from the central part of NY in the snow belt by Syracuse. I believe the truck was used for heavy long haul towing, as the rear had the gears replaced with 5.13's and the front was locked out with the transfer case. It also had cruise, trailer brakes, and an extra large fuel tank under the middle seat.
Good thing I didn't try and drive it as is, as I may have tried to put it into four wheel and had an issue.
Old 05-18-2010, 04:53 PM   #16
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Yep, that's a Powr-lok. I had a 1970 K20 that had a lot of early 1969 parts on it from the factory, and it had the same set up in the front. I wish I would have kept that drivetrain now. That truck would go almost anywhere.
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
