Old 02-11-2003, 04:33 PM   #1
1971Stepside
Almost Satisfied
1971Stepside's Avatar
Question How Hot?
I was wondering what temp the exhaust pipes and mufflers would reach under normal driving conditions. What about headers?
1971 C10 Stepside. LSx 6.0 with BTR Stage IV, Speed Engineering Headers, 4L80e transmission w/3200 Circle-D Stall. 3.73. Posi. Purchased this truck when I was 17. I started the rebuild (or take apart) in 1993. I have drug it around all over the country in pieces. Finally back on the road in 2021.
"I can't complain, but sometimes I still do. Life's been good to me so far."
1971Stepside is offline   Reply With Quote
Old 02-11-2003, 06:14 PM   #2
1971Stepside
Almost Satisfied
36 views....hmmmm
I was curious because I would like to have the exhaust powder coated or ceramic coated, but I needed to have an idea on the heat range to know if the powder would stand up to it or not....
Old 02-11-2003, 06:31 PM   #3
crazy longhorn
Fabricate till you "puke"
I would say ceramic on the headers. I couldnt really say how hot they get.......but i d@mn sure dont like getting my shoulder on the pipes when Im changing oil(OUCH). my system is pretty warm to the trans crossmember, the H pipe is just behind the crossmember........after that point, it cools down a bit. Good luck...crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
