Old 05-09-2010, 06:51 PM   #1
Choptop32
65 Upper ball joint riveted in
So I've ground off the rivet heads on the upper side of the ball joint, but still cant seem to get it off... using a screw driver and a BFH to try and drive and pry it off.. but no luck.
anyone have any tips?
is it cheaper/easier to just get a new upper control arm set up for the new bolt in ball joints?
Choptop32 is offline   Reply With Quote
Old 05-09-2010, 07:00 PM   #2
espkh3
Re: 65 Upper ball joint riveted in
I ground the head's off, then you can pry them out. Then grind down the remaining rivet, and finally use a air chisel to push them the rest of the way. Sounds like a lot but it's pretty simple.
espkh3 is offline   Reply With Quote
Old 05-09-2010, 08:06 PM   #3
Bears63
...just another truck junkie..
Bears63's Avatar
Drill into the rivet. You don't even need to drill it out completely, just drill into it from the top. Next, get a good punch and a heavy hammer and pop those rivets out. The hole you drill into the rivet will help by allowing the rivet to collapse it in. They will still be stubborn, but you can get them out. Just keep at it and they will eventually come out.
Mike "Bear" Shea
Bears63 is offline   Reply With Quote
Old 05-10-2010, 04:12 AM   #4
MXmaniac
MXmaniac's Avatar
Yep, definitely drill into them. Then they knock right out with a punch and a hammer.
Andrew
'69 C-20(292, 4-speed) Retired Daily Driver
'64 C-10(250, 3-speed) Fixerupper
'97 F*rd Mustang GT(4.6L, 5-speed) Daily Driver
If I only wanted two pedals I'd have bought a bicycle.
MXmaniac is offline   Reply With Quote
