Old 02-11-2003, 05:57 PM   #1
HotRod929
HotRod929's Avatar
Location: Bondurant, IA but in Worcester, MA for school
Brake Bleeding Procedure???
I want to bleed my brakes this weekend and I have never done this before. How do I do this and what wheels should I do first? Any tips and what not would be apreciated. Thanks
HotRod
1970 Chevy C-20
350 V-8
Turbo 350 w/ shift kit
Dana 60 w/ 4.10 gears AND Powr-Loc POSI
New Additions:
Summit Headers
135amp alternator
Proform HEI
Edelbrock 1406 600cfm carb
Sunpro Tach
Powr-Loc POSI
Edelbrock Performer RPM Intake
MSD 6A Ignition Box
AIM: HotRod929
Visit My Site: http://1970chevy.netfirms.com/
HotRod929 is offline   Reply With Quote
Old 02-11-2003, 06:23 PM   #2
68 Suburban
68 Suburban's Avatar
This link should help you:
http://www.73-87.com/garage/bleed.htm
68 Suburban is offline   Reply With Quote
Old 02-11-2003, 06:35 PM   #3
mikej71
Unregistered User
mikej71's Avatar
I use a MightyVac, and it works really well on the wheel cylinders. Makes it a one-person job.
71 SWB Stepside
SB400/TH350
mikej71 is offline   Reply With Quote
Old 02-11-2003, 06:49 PM   #4
Fred T
Cantankerous Geezer
Fred T's Avatar
It is also recommended that you flush the system. Manufacturers call for a flush every year, I recommend every other year. This is because brake fluid absorbs water and is easily contaminated. To do this, bleed each cylinder until clean fluid comes out.
As for fluid type, go with either DOT3 or 4. DOT5 is a silicon base, and requires replacement of all rubber in the system.
It will take most of a quart to flush your system. If you buy a quart bottle and don't use it all, don't keep it around. The fluid will absorb the water from the air that enters the water. I would buy 2 or 3 of the small bottles.
Fred
There is no such thing as too much cam...just not enough engine.
Fred T is offline   Reply With Quote
