Old 05-10-2010, 01:42 AM   #1
andyh1956
8 lug stuff
does anybody know if the front suspension on a van unbolts & rolls out like the pickups? i have a late 70s c30 van at home & when i go home on leave i am going to check on a 60-63 lwb sitting in a boys carport. dont know if it dont drive or owner dont drive anymore but thought it would make a cool 3/4 ton truck if the van stuff would work. it is 350/350/14 bolt on propane & i traded an oil change for it. runs perfect but i have never even looked under a van so i dont know whats under there or even how to get the engine out. thanks!
andy
andyh1956 is offline   Reply With Quote
Old 05-11-2010, 01:19 AM   #2
Captainfab
60-66 Nut
Re: 8 lug stuff
The full sized van suspension is essentially the same as a pickup. However the track width on the vans is wider than a pickup. Not having compared them part for part, I'm thinking that the difference is in the crossmember. That would make the most sense to me. If that is actually the case, you could still switch to the van spindles with rotors and calipers. You will need to switch balljoints as well.
Old 05-11-2010, 07:50 AM   #3
62gmc910
62gmc910's Avatar
Re: 8 lug stuff
The C30 van spindles should be the same as C20 pickup, the cross link is longer and the rear axle is wider, those knuckles will fit the 60-62 1/2 ton lower balljoint tapers if you remove the topping edge from the spindle lower holes, the uppers from the newer truck bolt in.
62 GMC 910 short fleetside 454 super t10 14 bolt
w/gov lock 70s c20 front discs (built in the 80s)
65 GMC 930 dualwheel 292 4spd all origonal 39k mi(my sons truck)
63 GMC 950 camperized school bus, (Gus the bus)
350 4speed 2 speed rear
64 GMC 950 "spare" bus 283? 4speed detroit locker
53 GMC 1ton dual wheel bus
78 GMC c25 short course off road race truck(son's truck)
355 th400 14 bolt (www.wheel2wheel.ca)
88 Peterbilt 379 longhood (hauls race truck)
62gmc910 is offline   Reply With Quote
Old 05-12-2010, 01:14 AM   #4
andyh1956
Re: 8 lug stuff
ok thanks. i would have crawled under & looked myself if i was at home. i am prolly gonna let this project go, i have about a dozen to keep me busy untill i'm ready to croak out. i will go see if sidney will sell his truck when i get home on leave & keep yall posted on that. thanks!
andy
