Old 05-10-2010, 01:38 PM   #1
62much
62much's Avatar
Tie rod adjusting sleeve question
Hope this isn't to dumb of a question, but I'm not a front end expert by any means. I just replaced the tie rods on my 62 1/2 ton, but kept the stock adjusting sleeves (LOOKED FINE) and after adjusting the toe in, tightened up the nuts on the sleeves. The question is, should I still be able to turn the sleeve in or out. I can put my wrench on it, and turn it kind of easily - doesn't seem right, shouldn't the nuts on the sleeve keep it from turning on the rods?
62much is offline   Reply With Quote
Old 05-10-2010, 03:24 PM   #2
dznucks
dznucks's Avatar
Re: Tie rod adjusting sleeve question
Yes, they should keep it from turning. i think the torque is around 22 ftlbs on those bolts.
dznucks is offline   Reply With Quote
Old 05-10-2010, 03:36 PM   #3
62much
62much's Avatar
Unhappy Re: Tie rod adjusting sleeve question
That's what I thought, time to spend more money on new sleeves I guess It just never ends!
Old 05-11-2010, 10:53 AM   #4
LMDGUY
LMDGUY's Avatar
I just got some new aluminum sleeves from CCP. Havnt installed them yet but they look like a great product
1973 C10 "Chain Reaction"
Street Trucks cover Feb 2012
2013 Silverado
1964 Cadillac
LMDGUY is offline   Reply With Quote
Old 05-11-2010, 09:52 PM   #5
87chevy.com
BMW & ASE Master Certified
87chevy.com's Avatar
depends on what your talking about.... is it turning on the threads, or pivoting on the ball joints. If you tighten the jam nut good an tight.. to spec even... you couuld get a pair of channel locks and grab hold of the sleeve and rotate it a bit. It doesnt rotate the sleeve itself, it rotates everything... take a look at that and see if thats whats happening.... more than likely, thats what happening
clint
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes
1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit
New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD
A poor man buy's it twice
finally got my domain name back, 87chevy.com.... site rework in progress
87chevy.com is offline   Reply With Quote
