Old 05-10-2010, 04:30 PM   #1
treetop_73
treetop_73's Avatar
Want to change air filter...
Hey guys. I don't know much about these trucks or the engines that came in them. This is what I have under the hood, 350...
I want to change the air filter to something like this... (I borrowed this picture from moneyeater, if you want it off, let me know.)
Name:  350 edelbrock intake 625 cfm carter carb.JPG
My question is, do I need to change the carb, or just the air filter assembly? And I seem to have more hoses coming from places than most the engines I see on here. And I don't mean all the other chrome on it, just the air filter assemby but this was the first pic I found.
Thanks in advance
'85 GMC High Sierra 2500
treetop_73 is offline   Reply With Quote
Old 05-10-2010, 04:53 PM   #2
harnalien
TruckincrazY
harnalien's Avatar
Re: Want to change air filter...
I had the same question/confusion when I first got my truck. That is the air cleaner and it is required if you have to have emissions testing. If you don't have to have emissions, then you can just buy an air cleaner base and top and slap them on. You can get a breather for the valve cover since you'll be removing that hose with the change.
harnalien is offline   Reply With Quote
Old 05-10-2010, 05:00 PM   #3
treetop_73
treetop_73's Avatar
Yea, I'm in CA. Arnold is a pain in my ass here with all these damn restrictions. Didn't he once have 15 hummers?
Anyway, yes, I want the new air filter as I like the looks a lot more than the closed unit but want to know if the new carb is needed or not.
Old 05-10-2010, 05:43 PM   #4
81ratrodc10
house of chevy's
81ratrodc10's Avatar
no they will work with stock carb just need to get a breather for your valve covers as stated above
81ratrodc10 is offline   Reply With Quote
Old 05-10-2010, 05:45 PM   #5
donut
donut's Avatar
You shouldn't, unless the open is made for another size carb.
'86 C-30 dually, 454/tbh400
'73 K-20 350/350/205 (sold )
I'm kinda like duct tape- no real purpose, but handy to have around.
donut is offline   Reply With Quote
Old 05-10-2010, 06:04 PM   #6
Oilbrnr
Oilbrnr's Avatar
Doubt it would pass emissions in CA if you changed to an open design.
Here in Phx. I couldn't even get away with the valve cover PCV inlet breather element. They said it had to be routed to the air cleaner as stock. (otherwise the open element was OK, but the truck was a 1980 K20 that skirted the then more restrictive laws by GM upping the GVCW)
Realize too, that your stock intake is receiving a colder air delivery currently, than an open type would... You could have it plated if you're looking for some underhood bling.
-Don-
'66 C10 w/factory A/C
'77 Cheyenne K5 350/465/205
'80 Custom Deluxe K20 350/465/205
'04 Denali XL
'05 DMax CCLB 4x
Have a Hickey Sidewinder Winch and need the owners/install manual? Send me a PM with your email address and I'll forward you a .pdf
Oilbrnr is offline   Reply With Quote
Old 05-10-2010, 06:19 PM   #7
GMC Guy
GMC Guy's Avatar
open air cleaners are pretty inexpensive. and can be installed in a few minutes. why don't you buy one, put it on. then when you need to smog, just put the stock air filter assembly back on? it's really easy
Greg
1974 GMC
1/2 Ton SWB Fleetside
L33 5.3/4l65e
.................__
............._____l __\__
..............l_(O)_ l___(O)]
GMC Guy is offline   Reply With Quote
Old 05-10-2010, 06:35 PM   #8
treetop_73
treetop_73's Avatar
Thanks for the replies. I think this is the route I will take. I just wanted to make sure I didn't need the carb changed.
I'm not looking for bling, I just can't stand the look of the stock assembly. Just looks cleaner to me with the open air.
Old 05-10-2010, 07:08 PM   #9
3r!c84
Badass
3r!c84's Avatar
http://www.summitracing.com/parts/SUM-CSUM103/?rtype=10
buy this to sine up everything!
Think outside the box?
-84c10 (1stcar)→My Build
-00 Saturn 5spd
drop a gear and disappear!
1/4:13:90
3r!c84 is offline   Reply With Quote
Old 05-10-2010, 07:29 PM   #10
treetop_73
treetop_73's Avatar
Originally Posted by 3r!c84 View Post
I was just looking at this to keep it all black
http://www.jegs.com/i/Edelbrock/350/...oductId=743329
But I like your price better
Old 05-10-2010, 07:31 PM   #11
3r!c84
Badass
3r!c84's Avatar
will loook like this
-00 Saturn 5spd
1/4:13:90
Old 05-10-2010, 07:34 PM   #12
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
Use a minimum 4" filter. If you don't, you'll choke your engine. It can run hotter and get worse MPG. The hot air in the engine will hurt performance. You'll add to it by using a small air cleaner.
Gerardo a.k.a. Mad Chemist
Silverado XST videos
gchemist is offline   Reply With Quote
Old 05-10-2010, 07:37 PM   #13
treetop_73
treetop_73's Avatar
I like the chrome but like the low key looking black too.
Thanks gchemist for the advice.
Old 05-14-2010, 04:34 PM   #14
CaliDude76
All About the BOWTIE
CaliDude76's Avatar
Cool Re: Want to change air filter...
Just a suggestion.... but I live in Cali too... and know all to well about the smog thing... Pops dumped a new 350 in my truck... and the stock set-up (had to leave it that way, so i won't compromise the smog reg's).. was starving the 350 to death.. what i did was, as you can see, is cut the body off of the original air cleaner... and gonna grab one from the junk-yard when i go to smog... this REALLY helped the perfomance!! I can actually hear the secondaries kick in now, and it flat moves..!!!
CaliDude76
"... Being "SQUARE".. is where it's at...."
Proverbs 15:30 .... "A Cheerful look brings joy to the heart, and good news gives health to the bones..."
Be exceedingly blessed today, my friends!...
CaliDude76 is offline   Reply With Quote
Old 05-14-2010, 07:37 PM   #15
treetop_73
treetop_73's Avatar
Looks to be the same color truck too.
I may look into that also. I tried to flip the cover but the hood doesn't close. But like I said, the look of the open air filter just looks better to me.
Old 05-14-2010, 08:18 PM   #16
Pyrotechnic
Pyrotechnic's Avatar
Cool idea on cutting the lid down. Doing the math on just the filter dimensions alone, that 12x5.5 filter would have a surface area of 207 sq in. The popular 14x3 filter would have a surface area of 132 sq in. Looks like a good way to get increased air flow on the cheap.
One interesting thing to note, these trucks come with a 12x3.5 filter stock, which has a dimensional surface area of 132 sq in...the same as the 14x3 filters everyone replaces them with!
Now of course the cotton gauze K&N style filters are going to flow more which is why a reusable 14x3 will still feel like an upgrade over stock...but just some food for thought when you choose your filter. Run the tallest you can that will still let the hood close!
1977 GMC Sierra Grande
Pyrotechnic is offline   Reply With Quote
Old 05-14-2010, 09:04 PM   #17
gchemist
gchemist's Avatar
Try a 4.5" K&N on a 305. The old 305 would scream up the RPMs to float valves!!
Old 05-14-2010, 10:54 PM   #18
CaliDude76
CaliDude76's Avatar
yeah i noticed the color thing too... I believe its called "saddle tan".. thats what the sticker on the fender well said.... its a cool color, get lots of compliments on it
CaliDude76
Old 05-14-2010, 11:34 PM   #19
treetop_73
treetop_73's Avatar
First thing the wifey said was that I needed to get it painted if it was going to be parked outside her house. She only likes white and black.
The paint is in too good a condition to warrant me painting now.
Old 05-14-2010, 11:40 PM   #20
CaliDude76
CaliDude76's Avatar
uh oh!.. the wifey stepped in huh..LOL good luck bro!!! Hey, is that the original paint-job? I know mine has been painted only once.. since the original paint.. same color
CaliDude76
Old 05-15-2010, 06:12 PM   #21
treetop_73
treetop_73's Avatar
The PO said it was original but I found evidence of it being painted. There is a spot behind the front bumper and on the cowl where the first layer of paint was missing in a spot and you can see the indention.
