Old 05-10-2010, 05:17 PM   #1
jamie72
jamie72's Avatar
Catalytic Converter replace on an 03 avy.
so the wifes o3 avalance with a 5.3 needs the catalytic converter replaced on bank2, and was qouted a price of 850-1100.00 for the job,where is good place to buy the assembly(do it myself) or buy the converters and save on the mark up ($), and let a shop weld them in??
give me some options guys... thanks... btw its throwing a code p0101,p0300, and a p0430 cat low system low codes..
thanks jamie
jamie72
72 BB cheyenne -- Restoration getting started..
member #807
http://www.myspace.com/whitetailobsession
www.antlertalk.com
jamie72 is offline   Reply With Quote
Old 05-10-2010, 07:08 PM   #2
bighaas79
Re: Catalytic Converter replace on an 03 avy.
Use gm cats. make sure its cats you need before you replace. If you have other codes make sure they are not causing the cat code to come up.
bighaas79 is offline   Reply With Quote
Old 05-10-2010, 10:06 PM   #3
clinebarger
The P0101/P0300 together is a dead give away to a plugged catalytic converter because the exhuast is come back through the intake screwing up the mass air flow sensor reading(P0101). The plugged catalytic converter is making all four cylinders miss on that side (P0300). Ive had good luck using aftermarket universal catalytic converters. Catalytic converters dont get melted down for no reason, you have more fuel running through the converter than it can handle from a missfire, or leaking fuel injector, or a leaking fuel pressure regulator.
clinebarger is offline   Reply With Quote
Old 05-11-2010, 04:07 PM   #4
jamie72
jamie72's Avatar
so i need to fix the cats then do a pressure check on the fuel system??
jamie72
member #807
www.antlertalk.com
Old 05-11-2010, 05:01 PM   #5
BarryB
BarryB's Avatar
replace both of them . if your gunna do it do it right. I just went thru this, one side was replaced then the other side went bad. so do em both at the same time. Listen to bighaas, he is the one that helped me alot when I was working an the 02 yukon.
*We could learn a lot from crayons... Some are sharp; some are pretty;and some are dull. Some have weird names; and all are different colours;but they all have to live in the same box.
* You may be only one person in the world, But you may also be the world to one person.
* Some mistakes are too much fun to only make once.
Two rules in life.
1. Never sweat the small stuff!
2. Everything is small stuff!
BarryB is offline   Reply With Quote
Old 05-13-2010, 11:34 PM   #6
truckdude239
truckdude239's Avatar
go to gm and get it the cat from gm is about 800 buxs last one i bought for work it had both cats and o2 sensors in it already its a compete down pipe
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
Old 05-14-2010, 01:00 AM   #7
clinebarger
Catalytic converters are not a wear item unless you have too much fuel or they get poisoned by lead,oil or antifreeze. Check the fuel pressure regulator first for fuel in the vacuum line.
Why are GM cats so much better? Aftermarket weld-on cats will work just as good.
Old 05-14-2010, 08:55 PM   #8
bighaas79
I recommend using the gm cats, because too many times I have had customers go and have cheap aftermarket cats put in, only to have p0420 codes come back. I'm not saying that an aftermarket cat won't work, however with as many times as I have had to replace aftermarkets with gm ones to remedy the issue, just save the chance of having to do it twice and put ones in that you know will work. If you are going to put an aftermarket one in, I recommend the best quality one you can get. I have found out that the reason the code comes back with an aftermarket cat is not that it doesn't clean the tailpipe emmisions, they do... however they don't do it quite the same as what the gm originals do. It has something to do with the metal and chemical makeup of the aftermaket cat not being the same as the gm. Some aftermarkets will work just fine but since I know I won't have any problems with the gm ones those are the ones I use
Old 05-14-2010, 09:43 PM   #9
truckdude239
btw all factory install cats have an 8year 80,000 mile warranty man dated by the federal govment. cline i've installed after market weld ins from napa, advance, and carquest. and on these trucks it and i have most of them come back and i have eating one gm cat due to an upset customer
David fuller
2000 Tahoe 5.3l 378
Old 05-18-2010, 10:43 AM   #10
SJBlazer
I ordered my cats for 2000 silverado off summit racing they were 350 (cheapest i found) fast delivery and installed with no problems
SJBlazer is offline   Reply With Quote
Old 05-21-2010, 10:54 AM   #11
Shon
If you want Magnaflow cats let me know.
71 Cheyenne C10 LWB cam'd 6.0/T56 Swap
Shon is offline   Reply With Quote
Old 06-07-2010, 09:11 PM   #12
BB4ME
browns recycling out of alabama factory rebuilt cats awesome prices should be able to get them 3-400 to you door
BB4ME is offline   Reply With Quote
Old 06-08-2010, 10:56 AM   #13
Houston54
The magnaflow cat assembly is around $400 at the parts house and installs easily. I see no reason to use GM parts unless they are price competitive.
Houston54 is offline   Reply With Quote
