Old 05-10-2010, 05:22 PM   #1
woodchip
Timing on a 396 eng
I know this has been ask before but I will ask it anyway.My service manaul says to set the timing 4 degrees BTDC ( 396 auto) at 500 RPM. But when I set it at 4 degrees it is very slow on pickup, and don't want to go. I set it 8 degrees and it runs much better, and has better pick up. Can anyone tell me what is correct for a 396 inch with a auto.
98 Chevy Z71 1500 extended cab
99 Dodge carvan es
68 Chevy C10 LWB 50TH 396 eng 400 Trans
62 Wheel Horse tractor in good shape
woodchip is offline   Reply With Quote
Old 05-10-2010, 07:17 PM   #2
hugger6933
Re: Timing on a 396 eng
The factory was real bad about having the timing retared too much on the big blocks. Even on some trucks I've owned [and sold] up into the late 90's you can crank in some advance and wake up the motor. Closer to 10 to 12 degrees is where I think you find your motor happyest. Jim
hugger6933 is offline   Reply With Quote
Old 05-10-2010, 08:07 PM   #3
woodchip
Thanks Jim I will try that tomorrow, I use to own this truck when it was new , and it would go when you hit it.
99 Dodge carvan es
