Old 05-10-2010, 05:47 PM   #1
bigdnew
Never Satisfied
bigdnew's Avatar
Control arm bushing - is this okay
just got my control arms back and one is a little bent in. will this be okay the other are not as bad as this one?
1973 4x4 Blazer- Parting Out
1986 LWB Silverado Undergoing LQ4/4L80E Swap
'86 Build Thread:http://67-72chevytrucks.com/vboard/showthread.php?t=390566
bigdnew is offline   Reply With Quote
Old 05-10-2010, 07:20 PM   #2
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
Re: Control arm bushing - is this okay
That's not too badb. I had one that was worse. It was bent nearly in half. I ended up replacing the arm. Replacing it may not be worth the trouble. You do have to remove the sleeve then press into another arm. For a daily driver, light use truck, keep it.
Gerardo a.k.a. Mad Chemist
Silverado XST videos
gchemist is offline   Reply With Quote
Old 05-10-2010, 08:17 PM   #3
bigdnew
Never Satisfied
bigdnew's Avatar
not a daily driver, will be running a 6.0.
Old 05-10-2010, 09:35 PM   #4
gchemist
gchemist's Avatar
You're okay. Wedge something between the edges and hammer it back with a 2 lb hammer. Problem solved.
Old 05-10-2010, 10:17 PM   #5
STOCKISH
Formerly- 1972SuperCheyenne
STOCKISH's Avatar
I agree, beat it back out.
--Josh
